20 Most Recent Acer Aspire 5670 Notebook Questions & Answers
2answers
What settings do I need
dont have to change any...connect s-video lead and press fn + the f key that has an icon of monitor on it (little square box)
for instance mine is f2 so I would press fn +f2 (not fn then f2 ,,fn and f2 together)
for most hp the f key is f4...
so you press togethher once and you have signal to tv ..press again you have signal on tv and pc press again and its back to pc only
1/23/2015 9:48:38 PM • Acer Aspire 5670... • Answered on Jan 23, 2015
Why is my Acer Aspire 5670 crashing?
Definitely a hard drive failure, pull the hardrive out if its no longer under warranty(the pc) and you can get hard drive tested kits that allow you to hook up the hard drive to a working pc and test the hard drive for errors, some are so fried they wont even read. The chirping sounds sounds worst case scenario. But it is deffinately a hard drive failure.
9/17/2014 11:20:55 PM • Acer Aspire 5670... • Answered on Sep 17, 2014
Hkgnj
adsgdfnudundjmhfnvlhdnjfndmskdnutpnfjlbfeekl;playingalongthe keyboardmakeyourunitcrashed..dheydflfmnjdmdd,
8/20/2014 7:21:14 AM • Acer Aspire 5670... • Answered on Aug 20, 2014
Sm bus controller?
you need to download the Intel chipset driver from Acer website click here Drivers and Manuals select notebook then Aspire then 5670 select XP as the Operating System download and install it hope that is helpful
8/9/2014 7:10:12 PM • Acer Aspire 5670... • Answered on Aug 09, 2014
2answers
Acer Aspire 5670 - Keyboard and mouse appear
Hello,You can restore the settings of your computer to a known good date. While in safe mode, do a system restore.Click on Start > Programs > Accessories > System Tools > System RestoreSelect a date when the computer was still working great. Launch it. Let it restart by itself. Once up inside the normal windows, update all device drivers. You can install RadarSync to scan and update all outdated drivers.I hope this helps!David
6/6/2014 1:39:45 AM • Acer Aspire 5670... • Answered on Jun 06, 2014
21answers
Touch pad and keyboard freeze after startup
Battery problem, remove battery... fixed!
12/29/2012 5:38:25 PM • Acer Aspire 5670... • Answered on Dec 29, 2012
Computer wont start
hello, try removing the ram and cleaning it. then insert it back. also make sure your CPU fan is working
10/17/2012 5:34:15 PM • Acer Aspire 5670... • Answered on Oct 17, 2012
I am having problems trying to install windows 7 on my laptop.it keeps giving me error messages that windows cannot be installed on this disk.pls help me.
maybe u dont have space on that disk .... or something is wrong with the CD
6/26/2012 3:24:04 PM • Acer Aspire 5670... • Answered on Jun 26, 2012
Aspire 4530 wont boot
The problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
4/13/2012 10:11:35 AM • Acer Aspire 5670... • Answered on Apr 13, 2012
Hhow to screen capture on Samsung 5670
CTL Print screen (PrtSc) will do it. You can then past this info into a document to send.
10/4/2011 2:20:49 AM • Acer Aspire 5670... • Answered on Oct 04, 2011
My acer 4150 laptop usb
Before using your USB, scan it for viruses, also run antivirus scan on your entire system. After antivirus scan, clean Windows registry using some reliable software such as Reginout. Now attach the device. Thanks
6/17/2011 5:07:35 AM • Acer Aspire 5670... • Answered on Jun 17, 2011
I have a password on
Just remove the CMOS battery on your motherboard to remove the password. Hope this would help. thanks.
5/30/2011 4:36:39 PM • Acer Aspire 5670... • Answered on May 30, 2011
3answers
Hi, can not get start up discs to redo my
Your redo disks should be damaged. Or your memory also could be damaged. In worst case, try to download the disk again from acer and burn it to a disk and try the new one. If it is not working yet, you should use a linux live disk to test your memory. If it is damaged, buy new memory RAM units and change it.
3/1/2011 11:31:50 PM • Acer Aspire 5670... • Answered on Mar 01, 2011
My mic isn't working keep
You must install the correct sound card driver for your OS. And then everything will work just fine.
3/1/2011 10:07:33 AM • Acer Aspire 5670... • Answered on Mar 01, 2011
2answers
All of a sudden my computer shut off n then wen
You probably should see if the driver for the mouse and keyboards is properly installed if that's all your having problems with. Go and re download the drivers from the website and see if that doesn't work.
3/1/2011 6:05:04 AM • Acer Aspire 5670... • Answered on Mar 01, 2011
Is it possible to connect
Welcome to Fixya. Yes you can use your Sony Bravia TV. After you connect the Laptop to the Tv press FN + F5 to toggle the display between the laptop and the TV.
Thanks for using Fixya.
2/21/2011 4:33:36 PM • Acer Aspire 5670... • Answered on Feb 21, 2011
Acer Aspire 5670 Notebook Logo
Popular Tags
140 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 5670 keyboard mouse appear
  • Computers & Internet
