20 Most Recent
Acer Aspire 3623WXMi Notebook Questions & Answers
Windows Media Player Keeps Popping Up.
ok, you need to type msconfig in the in the search bar in the start menu, when the window pos up select the startup tab and uncheck the boxes that says WMP in the name, and click apply and exit, reboot the machine so the registry is updated, now you will ahve the pc booting without WPM starting up at all!!!!!
any probz and post back'
kind regards and don't forget to rate us please
How do i enable bluetooth
Are you sure it has bluetooth because some Acer computers have a button for it but don't actually have the hardware.
To check go to the control panel and search for a device manager.
Once you open that look if there is a bluetooth device and whether or not there is problem with it.
Turn on your computer and wait for Windows to fully boot.
Then log in as an administrator. You will not be able to use Bluetooth under a non-administrator account.
Press the button with the Bluetooth symbol on the left side of the computer. This will launch the Bluetooth utility. From here you can sync and manage Bluetooth peripherals.
Press the Bluetooth button again to disable Bluetooth. This will disable all connections, but the utility will save your settings so the same devices will sync with the computer again when Bluetooth is re-enabled.
hope this helps
I need to install intel
Here is the webpage.
Just press the "Check you system for the lates updates button"
I can sadly not help you beyond this point.
I have formated my computer
IF had formatted the drive then the drivers and OS files could be lost and if so you will need to reinstall them specially the video drivers and the players.
Where do i find the souncard to download
check that the sound is not just switched off (bottom right of screen) if not try a system restore to the point when it was last working. if this fails go to acer web site (www.acer.com) and down load the sound driver from there.they are all free.
hope this helps.
MY LAPTOP DOESNT HAVE SOUND CARD
You laptop might not have a sound card but sound was built into it by using the chips directly on the board.
have you tried download and reinstalling the drivers?
Also the control panel has a sound application that supports "HD" sound?
There are quite a few ways to turn the sound off and on so I'll let you tell me how much progress you made.
Window media player keeps popping
Hello and thank you for using Fixya services.
From the sounds of your issue, it may be that you have malware or a trojan. You can run a scan using this free
malware/antivirus protection. I am not sure which antivirus you are currently using but this one is free and has excellent reviews. You will need to uninstall your current antivirus protection first before installing this one.
Malware/trojans can disable your antivirus programs and make it look like everything is running smoothly. By running a thourall scan with another program, you can get the malware out. Even the best antivirus can be disabled.
Please let me know i I can be of further assistance.
No wireless connection
1. Enable the wireless adapter on your computer
2. Move the laptop into range of a wireless computer (Starbucks?)
3. Scan for available networks
4. Select a network, and click "connect".
Windows Media player keeps popping up.
the file which doesn't has any name, is a spyware virus..
If it is marked please unmark it as it may cause several damage to ur system
If ur Windows Media Player is troublin u, click start,
Select Default Programs
Now Select the Windows Player as MP3 Universal Player..
After u do so, it wil take some time
After it is done, restart ur system
I guess it works..
Haier laptop
appropriete driver may not be installed. use your motherboard cd to installm them. if you do not have it try to find somone else who has the same model as your and if they do not work again go and ask for a Foxcom motherboard cd from a computer specialist. it is suitable for most motherboards and it will install all the necessary drivers for sound, vga, adapters and so on and so forth.
get back to me if that does not work too.
thank you
wonder
Laptop cd/dvd drive broke
Hi Kenn
yes u can replace your drive if u have the knowledge, if not seek professional help.Another thing it is not expensive.
WHATS UP WITH MY LAPTOP 3623
This issue normally means that your hard drive is bad. What the computer is trying to tell you is that it attempted to locate Windows, but it can no longer be found. The Hard drive is normally the case for this message. If you want to be sure its the hard drive I would suggest downloading http://www.knopper.net/knoppix/index-en.html and boot from this CD try and access the hard drive with this cd, if you cant the Hard Drive is toast. If you can the OS became corrupt and could still mean the Hard Drive is close to being toast. Either way throw the toast in the trash and buy a new Hard drive. http://www.newegg.com/
Have a great week,
ArmyMason
DVD DRIVE DRIVER FOR ACER ASPIRE 3623
Generally you don't need the Optical drive driver. Windows XP has built in drivers to support them. If you tell the exact problem then may be we can help
Acer aspire 3620 lid broke and screen needs to be replaced
If a 'qualified' tech damaged the screen, then it is up to them to replace the screen at their cost.
You could try finding screws slightly bigger and see if they will realign and stop it from being floppy.
Personally I would go back to the tech and complain untill they repair it properly.
Hope this helps a little.
