20 Most Recent KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Questions & Answers
3answers
Something wrong with the control panel on my
Some refrigerators are designed to cycle through the settings. If you continue to press the down switch it may cause the numbers to reach the bottom set number then go back to the highest number and start the cycle over. If so then all you will need to do is continue to press it until it gets to the desired number. That is how LG and Kenmore work at least on the models I have worked with..
8/1/2020 4:11:20 AM • KitchenAid... • Answered on Aug 01, 2020
0answers
Water dispenser stopped working
check to ensure the valve to the water supply is fully open, if so you may have a restriction (plugged) line or valve, this could be due to minerals or biological growth. if possible roll the fridge from it's location to access the rear where the water supply is connected, turn the brass fitting left to loosen to see if water begins to seep out, this confirms a water supply is available and the issue is likely a solenoid valve. My hunch is being neither are working at the same time the water supply is not available.
11/5/2017 10:46:28 PM • KitchenAid... • Answered on Nov 05, 2017
2answers
We bought a new Kitchen
Download manual from web site. Freezer should be around zero degrees and fridge around 39.
8/25/2017 2:50:31 PM • KitchenAid... • Answered on Aug 25, 2017
0answers
Not cooling
Be the first to answer 4/8/2017 3:00:08 PM • KitchenAid... • Posted on Apr 08, 2017Be the first to answer
Can you lay the KitchenAid refrigerator on it's side to transport?
No not at all don't do it.
9/5/2015 12:34:17 PM • KitchenAid... • Answered on Sep 05, 2015
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
9/25/2014 3:01:00 PM • KitchenAid... • Answered on Sep 25, 2014
0answers
0answers
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
149 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
water dispenser stopped working
  • Refrigerators
