20 Most Recent KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator Questions & Answers
My KitchenAid Superba refrigerator in-door water dispenser frozen
your first idea is probably the fastest. Hair dryer. That's what I'd do no need to make it work overtime to cool back down.
1/31/2018 4:45:02 PM • KitchenAid... • Answered on Jan 31, 2018
My KitchenAid KSCS23INSS00 refrigerator double beeping. Compressor is working and I see some ice in freezer evaporator era but temperature in freeze and in refrigarator not going down. Frame beetween
Make sure your coils under fridge are not obstructed. The Black grill at the bottom pulls strait off allowing access to the coils. There is a long skinny brush made for the purpose of cleaning the pet hair and dust bunnies from between the coil rows. If you have a pet this is a regular task. The brush can be purchased at most hardware stores, just ask for a coil brush. Without sufficient air to pass across these coils the return Freon doesn't have a way to dissipate the heat.
9/19/2014 3:04:17 AM • KitchenAid... • Answered on Sep 19, 2014
Ice maker does not work
I have the same problem with the same brand refrigerator. Order a new ice maker and replace.
3/2/2012 3:29:41 PM • KitchenAid... • Answered on Mar 02, 2012
0answers
The handle of my side by side Kitchen Aid
Use an allen wrench (hex) to remove loosen the set screws in the two handle holes. Once removed, tighten the mounting lug. Replace the handle and tighten the hex set screws.
10/27/2010 12:09:22 AM • KitchenAid... • Answered on Oct 27, 2010
The freezer is not as
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/8/2010 3:16:11 AM • KitchenAid... • Answered on Aug 08, 2010
What tool do I need
this is a #10 torx
8/3/2010 12:53:42 PM • KitchenAid... • Answered on Aug 03, 2010
No ice forming
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
6/9/2010 3:33:41 AM • KitchenAid... • Answered on Jun 09, 2010
2answers
My KitchenAid KSCS23INSS will not make ice. The
your model has the ice bucket on the door . and it uses a infred eye system . if your open door and hold the right side closed the lights can talk to each other . if the blinking is in multi of 3 . it has a problem . if it blinks reg .pattern . then itcould be icek mker it self or water valve. ( dual valve in back .. . the sensor is most common .. about a 80 .oo kit .. mm Hint . behind the grill you will find a tech sheet that will tell you the codes and how to test . **** hope this helped ..
1/31/2010 1:18:24 AM • KitchenAid... • Answered on Jan 31, 2010
I suddenly have frost in my frost-free freezer?
usually this would be from a door seal or the door not getting closed all the way.
5/20/2009 3:38:52 AM • KitchenAid... • Answered on May 20, 2009
2answers
KitchenAid French door refrigerator. How do I repair a non-working water Dispenser on it please?
Troubleshoot step by step and if that fails, resort to a professional: Check the Basics: Make sure the refrigerator is plugged in and receiving power. Verify that the water supply to the refrigerator is turned on. Inspect the Dispenser Actuator: The dispenser actuator is the component that activates the switch to send voltage to the dispenser. Check if the dispenser actuator is damaged. If so, replace it with a new one. I list a procedure for testing this actuator at the end of these basic steps. Frozen Water Tube: Disconnect the water supply tube at the bottom of the door. Blow air through it. If air doesn't pass through, the water supply tube may be frozen. Thaw it out and ensure the freezer is set to the proper temperature (0-10°F) to prevent future freezing. Water Inlet Valve: The water inlet valve opens to supply water to the dispenser. Ensure the water pressure to the valve is at least 20 psi. Use a multimeter to test the water inlet valve for continuity. If it lacks continuity, replace it. Check Water Filter: Remove the water filter and dispense water. If flow increases, the filter may be clogged or incorrectly installed. Replace the water filter if needed. Verify Water Supply Valve: Ensure the water supply valve (connected to the refrigerator) is fully open. If disconnected during service, it might not have been turned back on fully. And now, the testing of the actuator. To determine whether the dispenser actuator in your KitchenAid refrigerator is damaged, follow these steps: Visual Inspection: Look closely at the dispenser actuator. Check for any visible signs of damage, such as cracks, chips, or breakage. If you notice any physical damage, it's likely that the actuator needs replacement. Functional Test: Press the dispenser lever or button as you normally would to dispense water. Observe the response: Does the actuator move smoothly and engage the switch behind it? If the actuator feels stiff, loose, or doesn't move at all, it may be damaged. Listen for Clicking: When you press the dispenser lever, listen for a clicking sound. The actuator should make a distinct click as it activates the switch. If there's no click or an unusual noise, it could indicate a damaged actuator. Multimeter Test (Advanced): If you have a multimeter, you can perform a continuity test on the actuator. Disconnect the refrigerator from power. Remove the actuator cover (if applicable) to access the actuator. Set the multimeter to the continuity (ohms) setting. Touch the multimeter probes to the actuator terminals. If there's no continuity (infinite resistance), the actuator is likely faulty. Remember to exercise caution when working with electrical components. If you're unsure or uncomfortable performing these checks, consider seeking professional repair assistance. Remember to consult your Owner's Manual for specific instructions related to your model. Much of this information comes from the RepairClinic site.
3/17/2024 4:42:35 AM • KitchenAid... • Answered on Mar 17, 2024
KitchenAid Refrigerator Model KSRS25Q. Are Replacement door seals available?
Question edited for a lot more clarity, 'make model (what it is)'. Question moved for correct category. Yes they are, direct or from Parts Suppliers. https://www.google.com/search?q=KSRS25Q+WH11+door+gasket ..
1/4/2024 10:29:11 PM • KitchenAid... • Answered on Jan 04, 2024
KitchenAid refrigerator superba is not cooling. Frizzer is fine
Possibly you r hhermostat in Fridge section gone bad. (if freezer working then most likely (if freezer at top & fridge has Iced up or food in the freezer or fridge Is Blocking the Air vents inside that circulates the cool air flow to Bottom or top, check & listen to see if Fan is working inside freezer /fridge worst case scenario is (if you have a p.c board on top , that could b a Fault there also (then you need a Tech, ).
10/26/2023 4:15:12 AM • KitchenAid... • Answered on Oct 26, 2023
KitchenAid KBFC42fts - light turns on but control panel won't work. I have turned off and back on via the circuit breaker. Is there a reset trick on the control panel?
You didn't say but you need to turn the breaker off for 10 minutes. Best to you.
6/22/2023 1:51:56 PM • KitchenAid... • Answered on Jun 22, 2023
KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator Logo
Popular Tags
19 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
kitchenaid kscs23inss will not make ice
  • Refrigerators
