20 Most Recent KitchenAid KSCS25IN Side by Side Refrigerator Questions & Answers
Water dispenser drip
91bdaa16-d6be-46aa-a287-0065152cf5fa.jpgWhen water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERESea Breeze
10/15/2013 8:33:15 PM • KitchenAid... • Answered on Oct 15, 2013
Have power but compressor no work
Tried unplug,replug it back in half or an hour later.Most of the time the the compressor will reset and kick in than it work again.This is a temp solution only,because most of the compressors in frig have this intermittent problems will died again because of over heat the design 24/7 plugin doesn't help especially continue of power to it.Replaced the frig if it more than ten years or replaced the compressor if less.
9/4/2013 2:58:32 AM • KitchenAid... • Answered on Sep 04, 2013
3answers
Ice Maker problem
Apparently lowering the temperature by 5 degrees in the freezer compartment will keep the input water tube from freezing. It is working fine now!
7/19/2013 7:37:05 PM • KitchenAid... • Answered on Jul 19, 2013
Freezer door very hot and
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/25/2011 1:24:46 PM • KitchenAid... • Answered on Aug 25, 2011
The ice maker is not making ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/22/2011 2:15:36 PM • KitchenAid... • Answered on Aug 22, 2011
Water Filter Cover broke.
If there is something on the frost of the filter you can grab onto with plier you should be able to pull out the filter. Withthe broken can the button wont push in since the cap locks into the latch for the filter
These are the part's for the cap all are the same except letter at end indicates color
2260518W white
2260518B black
2260518AP grey
2260518T almond/tan
It could be purchased at your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
apwagner.com
repairclinic.com
midwestapplianceparts.com
Good luck in getting the filter out,
Gene
8/17/2011 5:04:30 AM • KitchenAid... • Answered on Aug 17, 2011
My ice maker has stoped working. There is a light
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/1/2011 12:23:34 PM • KitchenAid... • Answered on Aug 01, 2011
2answers
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
1/30/2011 3:29:35 PM • KitchenAid... • Answered on Jan 30, 2011
2answers
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
12/13/2010 7:58:49 PM • KitchenAid... • Answered on Dec 13, 2010
Our Kitchenaid side by side KSCS25INSS01 fridge
it could be your water
2/11/2010 2:37:13 AM • KitchenAid... • Answered on Feb 11, 2010
Ice dispenser won't dispense
I have a break down of the parts to that unit and I would like you to test a few thing like door switch and power supply at the motor and were the motor gos in. I will return with a like because some reason I believe Fixya must be trying to cut down on photos to reduce bandwith cost. I have to do the same out side of my forum also. Now you wonder where all those ads come from? Hey, you said handy, you may be working around 110 volts and inside a good grounded refrigerator, anyway just need to mention that I do wan't to hear back from you, Sea Breeze
1/6/2010 7:04:48 PM • KitchenAid... • Answered on Jan 06, 2010
Water leakig out of the top panel in freezer by
the back panel need to be open (inside the freezer ) and see if there is build up of ice there the make it, also :
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
1/3/2010 5:56:29 PM • KitchenAid... • Answered on Jan 03, 2010
KitchenAid KSCS25IN Side by Side Refrigerator Logo
50 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
water dispenser drip
  • Refrigerators
