20 Most Recent
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Questions & Answers
What is gapesa
G- given A- asked P-process E-equation S-solve A-answer
an anagram of the process used to solve certain problems such as algebra etc.
Is algedra the only tip of math that an
In general no. He/she will need some elementary vector calculus as well if he will try solve problems regarding design of various circuits powered by AC. Some elementary integral/differential calculus will be useful if he/she wants to solve more complicated problems with respect to power/energy consumption for example.Let just say Algebra is a MUST!
HOW DO I calculate my BMI IN MATH PROCESS
Assuming you are in the USA and use these units:
W is your weight in pounds
H is your height in inches
BMI = W / H^2 x 703.
So if your height is 5' 10" (70") and weight is 180 lbs
BMI = 180 / (70 x70) x 703 = 25.82
So <18.5 is thin
18.6 to 24.9 is healthy
25 to 29.9 is overweight
>30 is obese
How do you find the area of an irregular rectangle
There is no such thing as an irregular rectangle. This being said, I believe that the area of a parallelogram is still equal to the product of the base by the height.
Draw your parallelogram with one side horizontal. From the next corner, draw a line perpendicular to the base. The length of the segment you just drew is h. If b is the length of the base the area is b*h.
Hope it helps.
R=8cm, volumne=2411.52 what is the height?
Is this a right circular cone or a right circular cylinder?
Volume of cylinder= Pi*(r^2)*h
Volume of cone is 1/3 of volume of cylinder with same height and radius.
Solve for h
h=(Volume)/(PI*r^2) for cylinder
What is the definition of rational numbers
Any number which can be written as the ratio of 2 integers, eg 22.5 , which can be written as 45/2. Every finite decimal is a rational number. Since in the general ratio p/q, q may equal 1, every integer is a rational number.
Many numbers do not fit this definition, the best known of which is Pi, or maybe SQRT(2).
Prime numbers list to 100
2,3,5,7,11,13,17,19,23,29,31,37,41,43,47,53,59, 61,67,71,73,79,83,89,97
Number of pages
If you use ALL small type, it will be 20 pages. Seems like the thing to do, but if you must use 21 pages, you can use 17 pages of small print (40,800), and 4 pages of large print (7,200) for a total of 48,000.
Please explain how you do ratios
A ratio can be simplified by dividing both sides of the ratio by the Highest Common Factor (HCF). The highest common factor is the largest number that goes into both numbers of your ratio. In example 1 you are asked to simplify the ratio 6:8. Here the HCF is 2 so divide both sides of the ratio by 2 to give 3:4.
https://www.youtube.com/watch?v=cbjQWf411O8
