20 Most Recent
ASUS V6J-X009P Notebook Questions & Answers
Asus V6J reset cmos button please
The computer should show you a key to hit to enter the setup. Nomally the keys may be F2, F10, DEL, or some other key.
If your computer does not even give you any display, then you can't enter setup--it's failing the POST which means it won't work at all.
In a laptop, you could take it apart far enough to find the CMOS battery and disconnect it to reset the CMOS, but I'm thinking you might have a hardware problem here--like maybe a motherboard.
One thing you can do is unplug it, remove the battery, then reinstall the battery, plug it in and try again. In a laptop, anything further will require dissembling the case.
Asus v6j bricked
Did you pull the Cmos battery. Also on the mother board should be a switch or a jumper that should reset the Bios, or shock it out of its brick state.
Screen fliks change calor
Sounds like the cables between the display and the mainboard inside the laptop are broken and would need to be replaced. Those cables can be hard to locate, you may want to take the laptop to a repairer who can obtain the parts for it, or contact asus if you are still in warranty.
if this is a desktop computer then just replace the cable between the display and the computer.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
