20 Most Recent Garmin GPSMAP 60CSx GPS Receiver Questions & Answers
Try your local phone doctor. My local one fixed my camera for a reasonable price though I had a few weeks wait for a part to arrive from China.
Garmin GPSMAP... | Answered on Jan 29, 2018
Tip
Get Better UK Maps For Garmin GPS For Free
Because my GPSmap60Csx wont run Garmin GB Discoverer maps was thinking of buying a new GPS £££.
until i discovered that a much better map could be installed for free
This is a great way to upgrade a GPS unit
So If you like hiking and want a better map than the standard basemap on your GPS unit and it is one of these models
Garmin GPSmap60Cx & Csx
Garmin GPSmap62
Garmin GPSmap62/64s, cs and st[4]
Garmin GPSmap76Cx & Csx
Garmin Etrex 20 & 30
Garmin Etrex Legend Cx & Hcx
Garmin Etrex Venture Cx & Hcx
Garmin Etrex Vista Cx & Hcx
Garmin Colorado 300 & 400
Garmin Dakota 10 & 20
Garmin Astro 220
Garmin Oregon 200, 300, 400, 450, 500, 550, 600 and 650 including t models
Garmin Montana 600 & 650** including t models
Garmin Monterra
Garmin Edge 605, 705,
pop over to this website as link says it is free
FREE British Isles and Ireland Maps Home talkytoaster
Tried it on mine was so impressed i bought a more detailed one for £10
Order Page talkytoaster
Now I have a Garmin GPSMAP 60CSx with a very good detailed Uk map Comparable to the Garmin GB Discoverer maps for a fraction of the price
Hope someone else finds this tip useful
on Jan 15, 2015 | Garmin GPSMAP 60CSx GPS Receiver
The on/off switch on these were problematic.. so you might want to look at the linkage and switch before digging deeper, below.
Corrosion is a problem. If you can clean it up, you should. If the corrosion is a result of a leaking battery, you should disassemble the device as far as possible to allow access to areas that have been contaminated with battery acid. I like to use a q-tip dampened in a mixture of baking soda and water (about 10% baking soda and 90% water). Battery acid conducts electricity and must be removed. Anywhere it is results in changes in the values of components and can cause a great deal of problems.
You may also be able to exchange for a modest sum with Garmin for one of their rebuilt units - if available.
Garmin GPSMAP... | Answered on Jan 10, 2015
Hi Robert,
try the webupdater and update the GPSChipsetTypeG.
It will solve your problem.
I hope it can help You!
Kind regards,
Silva.
Garmin GPSMAP... | Answered on Oct 24, 2014
take a look on the old messages and You will find a solution posted for me.
Garmin GPSMAP... | Answered on Oct 02, 2014
This problem is Mac OSX related and can be solved using Cleaneject http://www.javawa.nl/cleaneject_en.html
The OSX operating system creates several invisible files and folders on USB-disks, camera's and GPS devices and the Garmin GPS devices can't cope with these invisible files and folders.
Cleaneject erases the invisible files and folders.
Garmin GPSMAP... | Answered on May 08, 2014
Resetting will not delete tracks - you must delete the track(s) individually. Your manual is here. Turn to page 26 and read "Using Tracks" to learn how to delete them.
Garmin GPSMAP... | Answered on Dec 08, 2013
use the webupdater and replace GPSChipsetTypeG file.
Kind Regards,
Silva.
Garmin GPSMAP... | Answered on Nov 09, 2013
Try to run the web update and replace all.
Regards,
Silva.
Try the webupdate and answer "replace all" it asked.
Kind regards,
Silva.
Garmin GPSMAP... | Answered on Oct 21, 2013
Garmin GPSMAP 60CSx GPS Receiver Logo
120 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
John Egan
John Egan
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
Garmin GPS
  • Garmin GPS
Most Popular Question
4yr old garmin gpsmap 60csx ceased
  • GPS
