20 Most Recent Dell Latitude D620 Notebook Questions & Answers
I want to import some audio through the mic input. Does anyone know if this input can be used for both stereo and mono? - the manual doesn't say.
why not just do it and listen or use AUDACITY , FREE APP pc IS RELIC
5/2/2022 3:06:49 PM • Dell Latitude... • Answered on May 02, 2022
2answers
My new dell d620 will not play dvds
You will need to install what is called a codec pack but the easiest way to solve your problem would be to download and install a free program called VLC media player. VLC will play just about any DVD without a problem.
12/18/2019 6:43:45 AM • Dell Latitude... • Answered on Dec 18, 2019
2answers
Location of bios chip on dell latitude e6400
My service tag:H8W55L1.
Pls email me at : [email protected]
3/21/2019 2:41:55 PM • Dell Latitude... • Answered on Mar 21, 2019
My latitude d620 is not reading a devices even after months of using it
Check the device driver, sometimes the newest drivers do not work the best. Downgrade your driver and see if it is recognizable.
2/24/2018 5:42:02 AM • Dell Latitude... • Answered on Feb 24, 2018
Dell D620 USB device not recognized
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time. Dell Technical Support Phone Number 1 800 204 4427 USA Canada
5/23/2017 11:31:45 AM • Dell Latitude... • Answered on May 23, 2017
2answers
Restore Factory Settings on Dell Latitude D620 (refurbished)
Restart your system. As soon as the computer reboots and when you see the blue line on top of the screen with a label www.dell.com that the time that you have to hit ctrl+F11. Once Dell PC Restore appears click on the restore button.
Best of Luck
12/12/2016 8:05:19 PM • Dell Latitude... • Answered on Dec 12, 2016
I want to install whatsapp in my laptop.
To install this app on a pc please follow the steps in the link bellow. you will first have to download an Android emulator in order o use the app since this is android os app. Hope this helps. http://whatsappforpcworld.com/whatsapp-for-pc-download-windows-7-computer-free/
1/14/2016 7:03:45 PM • Dell Latitude... • Answered on Jan 14, 2016
How to register a new person from current person
If the current person has Administrator rights, then go to the Control Panel and choose Users and Accounts to create a new user. How to Access the Old Control Panel in Windows 10 or Windows 8 How To Open Control Panel in Windows 7
11/15/2015 10:12:50 PM • Dell Latitude... • Answered on Nov 15, 2015
My Dell password is not working
Re-install the operating system....factory reset.
11/15/2015 8:23:12 PM • Dell Latitude... • Answered on Nov 15, 2015
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
7/11/2015 11:53:37 AM • Dell Latitude... • Answered on Jul 11, 2015
4answers
Need system unlock code for dell latitude
i can give master password
for any laptob dell or samsung or others
u can contact me on
[email protected]
5/16/2015 8:35:51 AM • Dell Latitude... • Answered on May 16, 2015
Battery light flashs orange continusly on a dell
Two possible causes for flashing Amber battery light.1) Your battery won't charge and needs to be replaced.2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
4/5/2015 3:49:27 AM • Dell Latitude... • Answered on Apr 05, 2015
3answers
Can you add a slave drive to dell latitude d620?
how to video
12/16/2014 11:11:49 AM • Dell Latitude... • Answered on Dec 16, 2014
4answers
How to start my dell latitied d620 builtin camera
Did you recently reload Windows? It sounds like you don't have a proper driver or utility program for your camera.
Dell has a great support site. First find your Service Tag #. It will be on the bottom and is black with white letters. Go to www.dell/support.com. Enter the service tag number (not the model #), you will find all your drivers and support that you need.
11/26/2014 1:08:35 PM • Dell Latitude... • Answered on Nov 26, 2014
I have a problem with my dell laptop D620 it cant boot
Is it powering on at all? If so, do you see the Dell screen? If you do not see the Dell screen, it's not even POSTing. That usually points to a hardware problem. If you are seeing the Dell screen and it's not loading Windows, that is usually a software issue related to Windows (or it could be bad sectors on your HDD). If you are not seeing the Dell screen, try removing the battery and using only the power cord to power it with. If, however, it is not powering on at all, try a different power cord.
10/29/2014 2:56:16 PM • Dell Latitude... • Answered on Oct 29, 2014
How to reseat memory
Hi, You may want to use the below link for Dell Latitude D620 service manual: ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d620_service%20manual_en-us.pdf Refer page number 22 to reseat memory. Thanks and Regards. Kiran Kumar. #iworkfordell.
7/12/2014 1:15:45 PM • Dell Latitude... • Answered on Jul 12, 2014
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
6/5/2014 12:07:37 AM • Dell Latitude... • Answered on Jun 05, 2014
2answers
It says i need to use the "high speed" usb port for my mobile internet modem. Where can i find one
use USBView.exe fromWindows Driver Kit (WDK) or download USBView.exe only from http://www.softpedia.com/get/System/System-Info/USBView.shtml Install and click items connected. Check port speed.
5/3/2014 11:41:02 AM • Dell Latitude... • Answered on May 03, 2014
Dell Latitude D620 Notebook Logo
438 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
problem dell laptop d620 boot
  • Computers & Internet
