20 Most Recent
Dell Latitude D600: Pentium M 1.6GHz, 512MB memory, 60GB hard drive, DVD-ROM/CD-RW, 56K Modem, Network Ca... (LATITUDED600PENTIUMM16) PC Notebook Questions & Answers
I have dell d600.when i switch on my laptop.on
that the problem goes away when the pc heats up for a couple minutes would lead me to believe that the problem is a bad connection. in short driver issues and hardware failure rarely if ever fixes itself after 10 min of running, where a loose connection might tighten up as it expands in response to the` heat.
Replace dell d600 battery
I'm assuming that you mean the CMOS battery which keeps the date and time and configuration settings of your laptop. If so, here is a link to the location of the battery:ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d600_service%20manual_en-us.pdf
L key is not working
it may be due to keyboard faulty so please take it to the nearest servicing centre
My dell d600 if i on it after 5-10 minutes it will automatically off waht is the solution
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Cant find the modem modle numder
Connect the modem thru ethernet cable. Click Start >> Run >> Type CMD and press enter. Then, type ipconfig in the black box. look for default gateway : will look like 192.168.0.1. Now Open internet explorer and type in the IP address and press enter. It would ask you to enter username and password. On top, you would see the model number of the router. The default password for router can be googled. For netgear Username: Admin password: password
How do I upload pictures onto my Dell d600
If your photos are stored on a SD memory card then remove the SD memory card from the camera and insert the memory card into an USB memory card reader. Connect the USB memory card reader into the USB port of your Dell computer. The Dell wiil detect the card reader as an external storage device, you can then open the folder on the memory card that contains the photos and then copy them to your computer.
Password
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.
Click on one of these links todownload HIREN'S BOOTCD :-
http://www.hirensbootcd.net/
http://67.20.82.163/
AUTOMATICALY DOWNLOAD VIDEO CONTROLER TO FIX MY
Dell D600 Drivers can be downloaded from Dell Official Support. Select 'Video' and download the required drivers and install them
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
My computer's zoom level is at 100% and is in to
Right click on an empty space in desktop, go to properties.Then go to Settings tab.There you need to set screen resolution as 1024 by 768. You can drag the tab to adjust resolution.they click on apply ok thats it
Laptop battery not charging
If the battery of your laptop is not charging or taking any charge, this indicate that the cells within the battery are dead which means the battery
needs to be replaced,i will suggest you a replacement battery for your laptop. this will help fix the problem on your laptop.
Take care
MY SOUND HAS DISABLED AND ALL THE CHECK BOXS ARE
I suggest you re-install the audio driver.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
