20 Most Recent
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Questions & Answers
Belkin wireless G+ usb adapter
AOL has been and will always have problem (had to do repairs on AOL computers since 1994)
If you have a DSL or Cable connection why pay again for AOL? That means you are paying twice for the same internet connection - and AOL causes lots of problems.
For AOL problems, it is best to contact AOL.
Find my wep key
Oh, sorry I didn't see it in the title before. First, check the dirvers are properly installed for the adapter. Then if you don't have the wep key, connect by cable or other computer connected to your router (better by cable, as you can have restricted access to router setup menu from wi-fi). The WEP will be in WIFI config. section. If you cant log in to your router, try export the config profile out from another wifi connected PC and import it into new device wifi config software (if they support the same profiles). If nothing of this helped, you can still reset the router (find in manual- most often disconnect from power and push reset button for about 10 seconds) and setup WIFI with new WEP key. Don't forget to write the wep down. If WEP is not your problem but connectivity of the adapter to internet or network at all, describe the problem more deeply
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
Safari won't access web page with my iPad air
There are problems with the Belkin site. It may even be that someone has sabotaged it. I had problems using the Belkin drivers and discovered that two of the files (I needed version 2 files for my F5D7050 Wireless Adapter) were actually version 1 files and I found the correct files (all the same names, but different sizes) on the Drivers Guide site (do not download their download helper file - it messes up your computer and takes a lot of work to get rid of it). Also, searching for the drivers is made more difficult because one of them is actually misspelled on the Belkin site. Sorry I did not keep notes about which one I found was wrong.
Using belkin f5d7051 and getting wlancfgg.exe error message
There are problems with the Belkin site. It may even be that someone has sabotaged it. I had problems using the Belkin drivers and discovered that two of the files (I needed version 2 files for my Wireless Adapter) were actually version 1 files and I found the correct files (all the same names, but different sizes) on the Drivers Guide site (do not download their download helper file - it messes up your computer and takes a lot of work to get rid of it). Also, searching for the drivers is made more difficult because one of them is actually misspelled on the Belkin site. Sorry I did not keep notes about which one I found.
Ethernet controller error in device manager tp-link wn353g
Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking DM If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In Device Manager, locate the device under Network adapters, and then double-click the device name.
Click the Driver tab, and then click Update Driver.
In the Update Driver Software wizard, click Browse my computer for driver software.
Click the Browse button and go to the location on your computer where you saved the new driver files.
Click OK, and then click Next to install the driver.
