20 Most Recent
Philips PET824 Questions & Answers
I've tried all the tips. Do you know where I can
It's not operating perfectly. It doesn't always load the DVD on the first try. But once it's loaded, it plays through okay. I just kept moving the laser unit back and forth and cleaned the lens as recommended. I got the unit to where it would keep trying to load the disc and finally it recognized the DVD and started playing.
No Disc message
Turn off the power.
Open the lid and gently push the laser mechanism to the outermost point of the slot.
Power on and try a disc again.
Also try cleaning the laser lens with a mild foam cleaner and cotton swap. Leave to dry and re-try a disc.
If neither work, then the laser is probably faulty. If the unit will play CDs but not DVDs, then this is a good sign of a faulty laser.
Screen has a "haze" over 1/3 of it...rest is okay
This may be due to a bad contact in the connector. If you unscrew and remove the back cover, there is bunch of wires coming from the LCD with a male or female, I forgot, connector on the end, which plugs into its counterpart on the main board. That connector may not be fuly plugged in. The chance that this is indeed the case is no more than 10%. Unfortunatey it looks like this the electronics failure - 70% or LCD itself - 20%
Remote not working
there is a way to test the remote contorl. get a radio and put it on the am section. aim the remote control towards the radio and push the buttons on the remote. if it is working, you should be able to hear some statics from the radio speakers. try it and let me know. if you do not hear statics, they you need to open it and clean it with rubbing alcohol. use q tips to do clean the button on the board but be careful not to put any alcohol on the rubber buttons from the inside, it will ruin the finish on that. it will destroy your remote. good luck.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
