20 Most Recent
HP Md6580n 65 in. HDTV Questions & Answers
Will not come on red light only?
Same issue and still no solution. 2 red lights as soon as I plug in and wont turn on. I pulled out lamp and blew out the dust put lamp back in and nothing. Please Help!! e-mail me thanks Matthew Fulton
[email protected]
Hp dlp 65 shuts down
Shut downs occur for variety of reasons like
Over heating of processor
Any hardware component failure
Virus or any software issue
Battery problem for laptop and smps problem for pc
If u specify the exact circumstance and at what point the shutdown happens it will be easy to help.....
What cause polarization in HP TV
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there or do a search by type in the Brand Name of your device in
the Search Box, at the top right of the display window.
Fan problems...cannot hear anymore. Bulb
Hello
You can replce the cooling fan of your tV. For that, you have to open your tV. You must have a sound knoledge in electronics to do the work. If you have. preoceeding are given here. Follow it please.
[1]]Disconnect all attached components and the power cable from the outlet. Maneuver the DLP to allow access to the rear of the television. Allow the set to cool for at least one hour if it was recently used. [2] Remove the rear panel of the television and locate the cooling fan. It is usually located at the rear of the television casing near a grated opening for ventilation purposes. If multiple fans are installed, the cooling fan usually is the larger one. Avoid unnecessarily disconnecting any cables or components from the television. [3] Remove the projection bulb and set aside to avoid any damage. Avoid touching the bulb surface directly to prevent any permanent damage to the bulb. Note any cables or screws that you remove to allow you to reinstall them correctly.
[4] Unscrew the cooling fan case from the television housing and carefully remove it from its place. Disconnect any power cables from the circuit board that is connected to the fan. Remove the fan from the housing or replace the entire housing, depending on the manufacturer. Use compressed air to remove any dust or loose debris that can damage the television.
components.
[5] Secure the fan to the television. Connect any previously removed cables. Place the projection lamp housing back in place and replace the cover on the rear of the television. Power on the television to ensure the fan is active and no unnecessary noise is present.
Fan and its type number will be printed on fan's body itself. Look ofr the same type and number. OK.
My hp 65" dlp tv
Yes, I would advice you to replaced the lamp because high chance that it was already faulty and trigger the symptoms. The unit will not power up unless the bulb is in good condition because of the protection circuitry which will enable if there's a bulb malfunction. You may buy online for the replacement, click this
LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
