20 Most Recent
Sony BRAVIA KDL-26S2000 26 in. LCD HDTV Questions & Answers
My Sony Bravia lost its picture
Please check the connections on the back and hope that you find a loose video connector. If that doesn't fix it then continue onto the source to see if that might have a loose connector.
The next thing to check would be the other inputs using the TV/Video button to see if the video on all of the inputs is dead. That would be what might be called "bad news".
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
