20 Most Recent
Sony KDF-E60A20 60 in. LCD HDTV Questions & Answers
I cant access Netflex and when I try to access Netfles it shuts down TV
It could be the dns settings
What are you using to access Netflix laptop console phone pc
In any case try uninstalling Netflix then reinstall
If you ate using a game console try going to internet settings clear the settings and reconnect this should put all settings back to default You should now have Netflix enjoy
Blinking 21 times power red LED
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience
Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.Gillight
TV will not power up, no blinking lamp
hi caps don't have to be swollen to be fault that blinking light means you have no 5 volt standby, you need to check diodes capacitors transistors resistors may be best to look for a tech in your area, hope you get it working
regards
shaun
Red lamp indicator light flashing
How
many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known
as blinking codes. From the number of
blinks occur at one time switch ON; you can get an idea about the faulty
circuit stage inside the TV. This will
make repair easy. If you wish to get some details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic / Timeslide / Flipcard, can be
selected by the
drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the
brand name / model number / IC used, in the
search box at the top right of the display window.
Sony bravia kdl46ex500. red led light is blinking
These blinks are fault indication, and known as blinking
codes. From the number of blinks occur
at one time switch ON; you can get an idea about the faulty circuit stage inside
the TV. This will make repair easy.If you wish to get more details, check this link.
Mosaic
/Timeslide, can be selected by the
drop-down list, by the top left
of the display window, will make surf easy. You can also do a search, by type in the
brand name / model
number / IC used, in the search box at the top right of the display window.
