20 Most Recent
Sony FWD-50PX2 50 in. Plasma Television Questions & Answers
Flicker screen
If any buffer board is faulty, this kind of fault can occur. Might have a panel fault too. It will be best to contact any service technician, to make it confirm.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Picture flickers and clicking sound coming from back of t.v.
The Z-Sustain should be suspected.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1200 posts to different brand TVs now. Pull up
older posts there. Faults to almost all brand Plasmas will be the same as they are all built on similar chassis. Refer any one. You can get details.
Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
When the TV turned on
first,
make sure the TV is correctly plugged into the wall. You can try
another outlet. If that doesn't work, then your TV is certainly having a
power problem.
The issue you describe is consistent with a power
supply board issue. This is the board where the AC goes to. This
problem may have occurred as a result of irregular power supply, or
excess power supply or power surge.
The TV is receiving current
but cannot circulate or transfer the current to other necessary part of
the TV because of the defective power supply board. You might be lucky
it's just a blow fuse. Also a defective transformer can cause your TV
not to power on......
All these can be checked on the power supply board.......
But
more often bad capacitors causes problem on the power supply board. I
do not think the power board needs replacement, rather those defective
capacitors is causing this issue. Open unit up and take a look at the
power supply board.You will probably see one or more electrolytic filter
capacitors that are bulged up in the top-not perfectly flat like the
others.
The value of these capacitors will be different, most
likely they will be somewhere around-820 to 2200uF/25 V( or /10V
sometimes).
You can replace them with same values but I would
recommend the voltage rating to be higher(like 35V for an original 25V)
for reliability purposes.
What happens is,these bulged top
capacitors will cause a low and unfiltered DC voltage=main board will
malfunction(the relay will keep clicking until the caps are holding
enough charge to bring the voltage up over a threshold point).
You
can buy these capacitors at any Fry's or Radioshack store or you can
order them online at vendors like "mcmelectronics.com"(look for
electrolytic capacitors). After replacing these capacitor(capacitors)
most likely the normal operation will be restored. Or you can by a
refurbished complete power board to save you some stress.......
Note:
There may be also some other causes for this symptom ,like a defective T
con board ,or main board,but the bulged top capacitors are the most
common cause for this issue.
If you don't know about TV repairers,
take the TV to the nearest repairman to fix the fault for you. Also,
note that TV stores a lot of current, so wait a while before opening the
TV back cover.
Yours sincerely.
Elect_Comp.
Where can I repair power
Any tv repair shops,look for them on the telephone Yellow pages.U mean litterly the power supply board taken out of the tv unit,yes,if they except the job.All tv shops,like their customers keep their parts in the tvs,Some charged u to come out and have estamate for the cost for repair some don't charge just look at the problems to telling u.
My Sony Flat Panel Display
Unplug,replug tv back in an hour later.Tv now reset it self back to factory setting.Now it should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
The screen just went off. i can still here the
Power supply. Contact Vizio support, and they can point you in the right direction.
the VizParts people are the official parts suppliers, and they also have better pricing than anyone else on the web from what I've seen.
Swapping the power supply is pretty easy.
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
