20 Most Recent Sony SDM-S75A 17 in. LCD Television Questions & Answers
Could be the motherboard, or a fuse. Without having it in hand it is hard to tell what it is. Check to see if there is an inside fuse in it.
Sony Televison &... | Answered on Dec 07, 2019
That is because it is a DVD controller, not a TV controller.
Sony Televison &... | Answered on Dec 05, 2019
You will find it if you google it.
Sony Televison &... | Answered on Dec 01, 2019
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter.
2 red flashes is bad power board, solution replace power board or repair it.
Possibly tv reach its end. Save money and replace it with modern energy efficient tv.
Unless your Sony remote control is programmable, you are unlikely to be able to find a code for your Sansui TV.
Sony Televison &... | Answered on Nov 27, 2019
Use code search on your GE URC to find something that works. If a search through all codes contained in the URC fails, try a different one.
Hi Daya,
It is a panel fault. It can be repaired. But it is a tricky and risky job. To attempt this repair you need to be an experienced technician. If you are a technician, please let me know. I will give you the details.
Sony Televison &... | Answered on Nov 23, 2019
Whats the model of the TV?
Thanks
Or something is overheating You can try updateing your software. But if that doesnt work I would take it to a repair shop.
Sony Televison &... | Answered on Nov 21, 2019
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
You can enter the model # of your Blu-ray Player to download the firmware update for your player.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Sony Televison &... | Answered on Nov 13, 2019
Sony SDM-S75A 17 in. LCD Television Logo
Popular Tags
2 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
S Sony
  • S Sony
Most Popular Question
tv doesn 39 t recognize hdmi roku
  • Televison & Video
