20 Most Recent
Philips 42PF7320A 42 in. Plasma HDTV Questions & Answers
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
6/3/2017 2:32:58 PM •
Philips...
Answered
on Jun 03, 2017
Will not start when cold.
sounds like you have a weak power board, it could be a simple fix, its mostly to be weak capacitors, that will need replacing, you need to identify the faulty ones on the power board any that are rounded topped i.e not flat when looking from the side of them, they will need replacing with the same value i.e if they 16v 33uf then replace them with the same, also if the temp is on the 85c or 100c it dont matter but its best to replace them with 100c as they can handle more heat, as power board can get hot and over time the weak temp capacitors wear out due to the heat.
4/9/2017 1:36:55 AM •
Philips...
Answered
on Apr 09, 2017
How add a cooling fan to a plasma tv?
You can not install anything that is not specified by manufacturer. All you can do - make sure your TV have enough "breathing" room on it's back , top and sides. All Plasma Panels produce a lot of heat - it's "normal" operation. If you still unhappy with it you can put regular household fan on the back of the TV. I doubt that it would make any difference though.
9/3/2016 10:59:22 PM •
Philips...
Answered
on Sep 03, 2016
Philips plasma TV has blue screen. How do I fix it?
Contact the authorized service center for Philips. There are many reasons for this fault, and it a very skilled work to locate the fault in its main digital board. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/11/2016 1:12:57 PM •
Philips...
Answered
on Jul 11, 2016
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store.
I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on.
Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ?
Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
6/11/2015 5:45:29 AM •
Philips...
Answered
on Jun 11, 2015
