20 Most Recent Philips 32PF5320 32 in. HD-Ready LCD Television Questions & Answers
Perform the flashlight test and then repost your findings for an answer.
Philips 32PF5320... | Answered on Sep 09, 2017
You will have to troubleshoot the power supply to find and correct the problem.
Philips 32PF5320... | Answered on Jul 29, 2014
Check its speaker first. If it is found OK, check and replace the audio output card. Contact the authorized service center for Philips to buy a genuine card. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Philips 32PF5320... | Answered on Jan 05, 2014
That is what electronics technicians call a catastrophic failure. The power supply needs servicing
Philips 32PF5320... | Answered on Nov 09, 2013
Whenever a LCD screen has been damaged, it's not going to be cost effective to repair. The part will cost you nearly what the replacement cost of a new T.V.. Sell the good parts that are inside your T.V. on Ebay.
Philips 32PF5320... | Answered on Oct 23, 2013
You need to go to the section for TVs. I'm sure they can help you over there. :) Sorry.
Philips 32PF5320... | Answered on Oct 21, 2013
Three digit universal remote codes for Philips are: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
To know about four digit codes, and setup proceedings, visit this site "Electro-help". type in this site name to yahoo search box. Pull up older posts there.
Philips 32PF5320... | Answered on Jun 10, 2012
http://www.support.magnavox.com/html/index_us_en.html
You can go here and put in your tv model # and get the code from the support site
Philips 32PF5320... | Answered on Jan 03, 2012
your TV has developed a power problem.
You can try to fix it yourself or take is to a repairman.
Go straight to the power supply board. Look for any bulged capacitor or burnt component. If you don't find any, get a meter and continuity test to read the board so that you can detect the defective component and make necessary replacement.
Good luck.
Philips 32PF5320... | Answered on Dec 06, 2011
Do you have a power light on the TV and if so, is it lit? Is there any humming or clicking coming from the unit? How old is it?
Philips 32PF5320... | Answered on Jan 31, 2011
You have damaged the screen and there is no cheap repair. Replacing this screen is just as costly as buying a new TV. Sorry this happened. The screens are fragile and very expensive. Thanks for asking and show a few hands of support.
Philips 32PF5320... | Answered on Nov 11, 2010
If your sure there's not a problem with the HDMI cord and also the tivo box then you need to replace the small signal board Manufacturer Philips Part Number 313918888991 Description CBA SSB
It cost around 120-180 dollars.
Test your tv by using something else with a hdmi output if you can.
Philips 32PF5320... | Answered on Oct 14, 2009
try leaving the TV unplugged overnight (at least 8 hours). this should reset televison to origional defaut settings. If you are using a remote, you should use new batteries or put it in another room and use menu buttons on the tv itself it is equiped.
Philips 32PF5320... | Answered on Mar 31, 2009
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
38 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
light comes but screen black
  • Televison & Video
