20 Most Recent
Philips 42PF9996 42 in. HD-Ready LCD Television Questions & Answers
HMDI SNOT WOREKING
A software update is necessary. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
TV won't power up
not to alarm you but several models that had the ambilight feature were subjects of the consumer products safety commission recall
for shorting in the ambilight feature
this can be checked on the us products safety commission website
do a google search on your model number
assuming the panel is not one of recalls the tv probably needs the power supply board
there are several fuses on it ; one that you will find open
the fuse shorted for a good reason
there is power fet or sumthin on the power pcb dead shorted
put in a new board
call phillips consumer support and complain that you dropped way too much money on a flat panel tv when you could have bought a dlp tv
if thats too complicated buy a new one
Lines through flat screen
The only Item to fix a vertical line running through screen is to replace the panel itself. You can check the price at a repair shop or through parts.com for a rough estimate but I can tell you it will be more than what the TV is worth.
Phillips 42" LCD Mod#42PF722OA/37
This problem is related to two failures, one is the Power Supply Board, another one is the Y-Main Board. Troubleshoot procedures:
1. Disconnect the Vs Power Supply cable from the Power Supply Board,
2. Turn on the tv and check the Vs voltage on Power Supply Board,
3. If the Vs voltage is there, then the Y-Main board failed.
4. If the Vs is not there, then the Power Supply Board failed.
Philips cineos picture problem
Are there any magenetic devices like speakers or high amp stereo recievers next to the TV? These blotches could be because of electro-magnetic intereference. Try moving devices away (anything metallic or which has a magnet in it)
Tv won't stay on
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick
motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of
the burnt fuse in the TV. To fix that it has to be taken to the tech
shop.
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
