20 Most Recent
Philips 20PF5120/01 20 in. EDTV-Ready LCD Television Questions & Answers
What are the best color and picture settings for a 48" Vizio LED TV
Here's a page I use at work [CNN] to quickly analyze monitors and set them up without dragging out a colorimeter.
LCD monitor test images
It walks you through what to look for and what control to use.
Simply connect your computer VGA output to the VGA input of the TV.
You may want to go into your pc's display settings and enable a 2nd screen to allow you to be at the computer and mouse through the different test patterns.Have fun!
6/25/2014 2:47:37 PM •
Philips...
Answered
on Jun 25, 2014
Phillips Flat TV Model 20pf4121\105 (Flashing green led)
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
5/2/2014 2:20:35 PM •
Philips...
Answered
on May 02, 2014
Green light then nothing
again.
Best of luck.
Irishfreethinker
12/8/2012 8:58:43 PM •
Philips...
Answered
on Dec 08, 2012
Loud schreikin noise and cuts off.
it sounds as thought the main-board of the TV is arching or shorting out. This is due to a faulty component in the power section of the TV . It is about to completely go out.
The main board need to be checked for bad components.
4/23/2010 5:16:24 PM •
Philips...
Answered
on Apr 23, 2010
20pf5120
Are you connecting the tv to your source using the DVI, component (Red Green Blue + 2), or composite (Red, Yellow, White)?
Try switching the type of connection you are using. If you are connected via component, then switch to composite. If the problem persists even on composite connectors, then the issue lies with the TV. If the composite cable works fine, then the problem is most likely the cable you are using.
Press the sleep button, and make sure the sleep timer is set to OFF.
Unplugging the TV from the wall outlet resets the TV.
If you have a cable or satellite box connected to the TV, then try resetting the box also by turning off/unplugging from wall outlet.
Surge protectors can cause some occasional anomalies with LCD TV's (they're still a good idea) - just reset the TV to clear up these anomalies.
-Tha Mp3 Doctor
12/7/2008 11:50:21 AM •
Philips...
Answered
on Dec 07, 2008
PC display problem
Hey,
ik'm glad that atleast you don't have troubles with the reso.
Anyways if you got the same TV, then just do this and it should work, i have sometimes lost a little side of the screen too, but this helped me:
Take your TV remote
PC Menu-->Factory Preset-->Reset-->Yes
OR same thing just not automatic
PC Menu-->Picture-->Horizontal/Vertical.
I hope it fixes it for you.
10/11/2008 7:44:43 AM •
Philips...
Answered
on Oct 11, 2008
Green light comes on for 2 seconds and then nothing
most of the time the led in front of the tv will blink red and that will tell the technician wich circuit to look in. if it does blink at all when it shuts down then the problem is more than likely in the power supply. the part number for that is 313819875691
10/12/2007 10:26:39 PM •
Philips...
Answered
on Oct 12, 2007
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
