20 Most Recent
D-Link AirPlus XtremeG DWL-G520 (DBDWLG520) 802.11g/b Wireless Adapter Questions & Answers
Hello, I am almost certain that the problem is
HelloSorry for the delay in responds.From what i have read. you have already tried most of the fixes. There is still a couple of things we can try.Instead of using the repair function, rather go to device manager and uninstall the current driver by left clicking on the device and uninstalling it. After that, you will need to download the latest available driver for your current OS from the link below.Click
HERE to navigate to link.Then reinstall the driver again.If the problem still persists, you will ultimately have to reinstall your Operating system due to registry errors which causes the problem.Try the driver installation, and let me know what happens.Please feel free to let me know if you have any questions.Kind RegardsAndrea
I need driver for window 7
http://www.dlink.ca/products/?pid=DWL-G520&rev=DWL-G520&tab=3
The vistabeta drivers should work for windows 7.
I need driver
here it is
http://www.dlink.com/products/?tab=3&pid=DWL-G520&rev=DWL-G520_revB
hope this helps
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
