20 Most Recent Westinghouse LVM-42w2 Television Questions & Answers
It could be if you are using HD that the show is not broadcasted in hd?
Westinghouse... | Answered on Jan 10, 2018
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
Westinghouse... | Answered on May 14, 2017
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Westinghouse... | Answered on Mar 05, 2017
Bright and dark spots on screen might be due to the fault of the screen itself. In some cases, it will be reparable. Contact any service technician, because, if it is a repairable fault, the panel might need to disassemble.
Westinghouse... | Answered on May 24, 2013
For problems which are potentially heat related like this one appears to be, you can try a few different troubleshooting techniques which may help you narrow down the problem to a specific component or circuit board at least.
When you first turn the set on, before the screen artifacts appear on their own, you can use a hair dryer to artificially heat up certain areas on the circuit boards to see if you can induce the faults to appear earlier than usual.
Once the set has warmed up and the faults become visible, use a can of compressed air cooling spray to cool down specific areas on the circuit boards to see if that makes the artifacts disappear temporarily.
By systematically heating or cooling the various components and circuit boards you may be able to isolate the general area which is generating the fault.
Do not forget to test the TCON board as well. It seems to be the most likely suspect, even if you did just swap it out for a new one. It would not be too unusual to get a wonky board which is DOA right out of the package. You must remember that most spare parts for LCD TVs that you order online are just salvaged out of other broken sets with "unrelated" problems.
Here is a link to a short interesting Youtube video showing the LCD TV parts harvesting process in action:
http://www.youtube.com/watch?v=uCNEEuVhAWk&feature=related
Here is also a link to another Expert's solution to an LCD TV problem which includes links to his excellent and informative set of LCD TV / MONITOR TROUBLESHOOTING GUIDES:
http://www.fixya.com/support/t10008425-when_turn_tv_picture_flicks_off
These guides will give you some idea of the various problems with LCD monitors and the associated repair procedures.
If you choose to rate BUDMRTN's troubleshooting tips by clicking on the YES THIS WAS HELPFUL icon on his solution page at the above link, then I thank you very much for your time and consideration.
Please comment back here to this page if you have any details to add, have any questions, have difficulty with the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
Westinghouse... | Answered on Aug 17, 2011
Hello Jdreier520, I would be more than happy to assist you but would rather do it live. Please send me an email to westytech@westinghousedigital.com so I can better assist you. You can either provide me with a contact # or I can send you my contact information so you can call me at your earliest convenience. Please note I will need model #, serial #, and TW# all located on the back of the TV as well as what you have connected to the TV and how they are connected. Looking forward to helping you get your TV running in no time.
Westinghouse... | Answered on Jun 24, 2011
Hook up ur tv to the cable box to able to watch HD channels and standard channels together.
Westinghouse... | Answered on Apr 19, 2011
Are you asking for TV serial number or Part
number? There is never a Serial Number for part.
Serial Number TV - A4202DET063902680C
Part Number - VIT70023.51
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Westinghouse... | Answered on Jan 13, 2010
Hi
I believe this is a decoder issue, you need to get is checked by a qualified repair tech. and get it replaced/repaired. If the decoder is fine then unfortunately you need to get the main control board replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Westinghouse... | Answered on Oct 24, 2009
HI and by the way iam abhishek,
i think the problem is with one of these three components and i am sure ,,
1.An jungle IC on D-board
2.colour wheel
3.CRT tube
please check these three and repair it..if u dont have electrical knowledge about tv(soldering etc...)better to go for a tech..
thank u,,if u found this helpfull please rate it///
Westinghouse... | Answered on Jun 16, 2009
check the power fuse
Westinghouse... | Answered on Jan 19, 2020
Westinghouse LVM-42w2 Television Logo
21 questions posted
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
white spots tv screen
  • Televison & Video
