20 Most Recent
Westinghouse LTV-37WI 37 in. LCD Television Questions & Answers
I have a 37 in. 1080p Westinghouse LCD TV and
Hello, it looks like your inverter boards are going out. If you are atleast a bit technical you can open the units back cover, and get the part numbers for the inverter board, these are the (one or two (master or slave) boards) you can get the part numbers and check out different prices at
www.shopjimmy.com, or email Westinghouse parts department for price and availability at
[email protected].
No Picture
I have the same problem was working fine and less than 2 months bam red screen green lines top to bottom no image on any input just volume works....Now i will be a victim of there horrible warranty service
Control on tv do not work.
The only thing I can think of here is that your logic circuit on the TV is 'confused'. The best thing you can generally use to reset it is to disconnect the tv from the wall power for half an hour. That should reset everything. If that doesn't do it, you will need some kind of service.
Picture clarity
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
- Press the power button on your TV to turn it on.
- Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
- Look for the "Reset" option and select it.
- Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
- Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
