20 Most Recent
Kyocera Ecosys Fs-1128mfp 30ppm All-in-one Laser Printer - Fs-1128mfp Questions & Answers
How do I get rid of the black vertical lines for the Kyocera FS1128mp?
make a copy from the document feeder and see if the lines are there. then copy from the platen glass and see if the lines are there. then print to it and see if the lines are there. if the lines ONLY occur when feeding through the document feeder then check the slit glass VERY carefully for debris like gel pen ink and whiteout or other stuff. even one little speck on the thin slitglass will appear as a line on a copy through the adf. if it happens on ALL tests. then it could be a scored drum, bad dv unit, secondary transfer, or fuser.
Line down middle of scan
only frm the document feeder ? lay it on the glass if the lines gone check the slit glass or if you switch from oem toner to generic or viceversa get a new developer and drum also make surethe fuser dosnt look worn
Drum make a noice
unfortunately I don't think there is a way to fix the noise from the drum other then replacement if the machine is under warrenty rma the drum
How do I print double sided with this copier
pick print on both sides (flip long edge or flip short edge) in the print driver. go to kyocera support to download latest kx driver if the options are not found in your current driver
Where is the MP tray?
It's the small door at the very front of the machine...located directly above the main paper feed tray. Just pull it open and lower it down. MP stands for Multi-Purpose and is for different paper types and sizes that are not available from the main tray.
Waiste toner box full.....how do I clean or change
The waste toner sensor has detectedthat the waste toner reservoir (drum unit)is full.FS 1128 has drum and developer as separate unit, waste toner gets collected in the drum unit . Right or left side of the drum unit has a cap fasted with screw, open it and remove the waste toner.Refix the drum and this will solve the probelm
Machine showing machine failure call service
The waste box is integrated into the drum unit housing. DIRTY JOB without a toner vac. There are two ports (one one each side). The covers pry off. The service manual doesn't cover this because they want you to replace the drum.
FS1128 whats the setup for dev on this?... is it like the CS2550 ? U130
1-5-5 Developing section(1) Detaching and refitting the developing unitProcedure1. Open the front cover.2. Remove the developing unit.3. Check or replace the developing unit and refit all the removed parts.NOTE:When the periodic maintenance (replacing the maintenance kit, see page 2-4-4), perform following maintenance modes.1. U251 Clearing the maintenance count (see page 1-3-39) 2. U111 Clearing the drum drive time (see page 1-3-33)3. U130 Initial setting for the developing unit (see page 1-3-34)
