20 Most Recent
Gateway CX200X Tablet PC Questions & Answers
FixYa solutions for every thing
Resent problems
your best bet is to backup your actual data on the tablet. Then do a fresh install (formating the drive) instead of repairing. This should let the install go through 100%. If it doesnt then i would look into it being a HD issue. But its better to do the fresh install first. Usually does the trick
After reading the BIOS software, my Gateway CX200X gives the message: MBR error. what is this?
MBR stands for Master Boot Record. It is an essential piece of information written on the Hard Drive that allows the program to load. If the MBR is corrupted the computer boot process cannot proceed.You have to repair it.On old systems with a floppy drive you would get a Win98 boot disk on a floppy, boot the system using the A:drive (floppy) then use a DOS command to refresh the Master Boot Record. If your system is using Windows XP tablet PC edition you might be able to use the installation disk to boot to the recovery console and use the command FIXBOOT or FIXMBR. You can also reinstall the Operating System. I hope this answer gave you some starting point to investigate further. There are on the web some software vendors who sell system recuperation CDs. Some may be free other you have to buy.
Gateway cx200x we were told
It's time to take the notebook, and its power-supply, to a qualified technician, for professional trouble-shooting.
Screen won't rotate
Please press Ctrl + Alt + Up Arrow keys to rotate the screen. This feature is completely depending on the Video card installed in the Computer.
The charging circuit doesn't seem to be working.
Unfortunately, as far as I know, there is no "Replacement" part for this. It will have to be fixed by the Manufacturer. It isn't a "Part" per-say, but a circuit on the motherboard itself. If it is no longer working, then it is a hardware issue, and since it is a "Laptop" style computer, there is no way to simply fix it.
How do i replace the battery on gateway cx200x
remove main battery by sliding battery lock to unlocked position, then slide battery release latch and slide battery out. If you are looking for how to disassemble the notebook to change the bios/cmos battery, you can get the service manual at mpcdriver.com with complete disassembly, reassembly instructions and pictures
Gateway tablet cx200X, tablet features won't work/ pen etc
All,
There is DEFINITELY A PEN IN THE CX2620 stylii. I just replaced mine with a AAAA battery. The old one (which is a AAAA size, you can find these inside 9-volt batteries) had acid buildup on its positive end and that is why the pen went inactive. There is a lot of debate over this pen problem and I guarantee 90% of the time it's related to the battery. I can do a clean replace on anybody's CX2620 pen/stylii with a fresh battery for $10. If interested email me at [email]
[email protected][/email] . You pay for shipping, your total about $17 or so. I have never done this before but I just replaced mine flawlessly so I can do others. I know there are a lot of dead stylii out there and people don't know what to do, took me a while to figure it out.
Thanks,
Kevin Teman
[email]
Exact same problem!
Well, I couldn't find how to make hand written notes in Word. I did find this.
Windows Journal Scroll down the page till you get to the Windows Journal section.
Pen Office Third party software that allows you to make notes in Word.
Please don't forget to rate this solution.
No power up
Are you sure that the lock button is completely in the unlocked position? If so, once this happened to me, and I removed the battery for about 5 minutes, then reconnected it and the computer powered up.
