20 Most Recent
Gateway CX200S Tablet PC Questions & Answers
Physical memory sump
to fix this problem, try the below steps.
1. as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. one you reach the dektop..run a system restore if this as started happening recently. you can run system restore which will bring the computer back to an earlier time lets say few days back with the help of selecting the date in the calender in the system restore tool.
To go into system restore tool click on start select accessories and the system tools and then system restore.
Select restore my computer to an earlier time and click the date in the calender box once highlighted hit next and wait till the process completes once completed it will restart the system automatically and will give you a message your computer was restored successfully in case it says not restored then you can select another Bold date i mean a previous date to retry again.
2. boot to safe mode and folow the below steps:
Edit the registry: Start then Run and type "regedit"
Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager \ Memory *Management and double click the DisablePagingExecutive value and enter value 1.
Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager\ Memory Management, double click on the Largesystemcache value and enter 1 as value to increase the size of the hard disk cache
please let me know if this helps. else we need to repair the os and will let u know the steps if this does not work.
Bad Display
The usual symptoms of the ati2dvag problem are:
- PC crashes without warning, sometimes the display shows weird patterns before the crash.
- Resolution may revert to the lowest resolution settings upon restarting your PC.
- The CPU temperature may shoot up prior to crashing.
- PC may not be able to reboot back after the crash, unless you turn off the power supply unit of your PC and switch it back on again.
- Your PC tells you (sometimes only) that the ati2dvag driver has failed to function.
This is a universal problem afflicting thousands of PCs worldwide and can occur in totally new or old computers; it doesn’t discriminate. Imagine the frustration of buying a new PC only to have it crash on you after a few weeks and thereafter.
There have been many hypothesis’ postulated. Some say it is a very stealthy virus, some say it is an incompatibility with Windows XP SP2 and ATI, some say it is a problem with the hardware acceleration settings in the ATI graphic card, others say it is a problem within Windows XP itself…etc.
The 2 most common “solutions” are:
- Reinstall the ATI driver. You are advised to launch Windows in Safe Mode (press F8 before Windows boots), go to Windows Add/Remove programs and uninstall everything ATI. Remove the DAO/MDAC component as well. You can use the ATI removal tool utility which can be downloaded from the ATI website. The complete set of instructions on removing ATI can be found on the ATI website.
- Go to System Devices in My Computer > Properties > Hardware, and locate the option, PCI standard PCI-to-PCI bridge. This could under other names on your PC, so contact your PC vendor if you’re unsure. Right click, and select the “update driver” option. Manually search and install the PCI standard PCI-to-PCI bridge.
How do i load pictures from a sd card into
determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
I wANT TO CONNET MY LAPTOP TO MY CRT TV
What you need:
This is hard to define initially as there are so
many ways to achieve this depending on what type of television you have
and what video outputs your computer offers. You may also find that you
only want to attach the stereo, and leave the TV disconnected, or vice
versa.
.HDMI - High Definition Multimedia Interface: Ideally
we will all have an HDMI connection on both our television and video
card, but most likely don’t have it on either. Many new LCD screen and
Plasma displays offer this mother of connections. They are also
becoming a little more popular on Video cards. This will give you the
highest quality signal. This format can also carry audio. This is very
easy to connect from one device to another. It offers the same video
quality as a DVI.
here are some tips that will help
Computer has HDMI and TV has HDMI – Use HDMI
Computer has DVI and TV has DVI – Use DVI
Computer has DVI and TV has VGA – Use VGA + Adaptor
Computer has VGA and TV has VGA – Use VGA
Computer has S-Video and TV has S-Video – Use S-Video
Computer has RCA and TV has RCA – Use RCA
Computer has S-Video and TV has RCA – Use RCA with adaptor
Computer has RCA and TV has S-Video – Use RCA with adaptor
VGA port connection to old style TV
Right click an empty spot on your desktop, select properties. Click the Settings tab. Right click the gray-ed out monitor, select enable.
To push the image to that screen, press the Function (FN) key and F4 normally.
Battery fails to charge completely
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Screen brightness
Another way to adjust the screen brightness is to hold down the Functin key (blue, Fn) and then repeatedly press the up or down arrows (which also show the symbol for screen brightness on the keys in blue.)
