20 Most Recent
Sony KDSR50XBR1 50" Projection HDTV Questions & Answers
TV loses picture/sound after 5 minutes then comes back. Repeat
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Tint is yellow green
bad light engine call sony and see if your tv is one on the extended warranty list.
Sony KDS-R60XBR1 making noise
Sounds like the ballast is whats causing the issue the leads are probably charred at where the leads attach to the lamp connection. Pretty common problem when you hear that sound. I would check the ballast and if you need one you can get one from
www.tvcircuitboards.com
Tv cooling fan
which fan, the unit has at least two of them. You getting a fan error or what? The Sony sets do have a error buffer you can try to call up.
Cant search solutions for one symptom and 1 sony mod #
Since you are here you have a computer and Google?Google the model number with error code, or problems, or what ever issue you have to see what is out there.The Sony website also has this and any authorized repair shop can access their tech database with model and issues to model.
New HDTV bulb
I have just bought a second hand Sony 50 inch Projection & the owner from new (paid 1200 Quid) assures me he has never replaced the bulb in 6 years. Don't pay 190 Pounds plus, if you can loosen 2 nuts you can get an Osram bulb alone (not mounted) for 32 Pounds 55 Dollars delivered if you search well on E Bay
Sony sxrd 72
Best left to a professional, you have to remove the front screen and clean mirror, plus it might be the lamp or the optical block that is having an issue. the SXRD series has been know for this.
Flashing red lamp light on front of my sony tv
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
I push the power button
If the standby light is flashing 3 times. (your post says 3 times 7) I was unclear... A error code of 3 blinks inidicate that the door covering the lamp is not secure oer the lamp is not secure. Make sure the lamp door is seculy screwed down. ussally the door push a little switch closed. If this doesnt work the next thing to try is to remove the bulb carefully(dont touch the lens) and replace it making sure the bulb is in place securely. let me know if i can help any further
I have a Sony KDS-R50XBR1
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
