20 Most Recent Danby DDW1805W Designer Series Free-Standing Dishwasher Questions & Answers
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
7/16/2023 7:45:48 PM • Danby DDW1805W... • Answered on Jul 16, 2023
10answers
GE dishwasher nautilus - bottom tray caster wheels come off daily.
I finally found a solution after 2 years! Appliancezone.com has wheels and studs to fix problem. WD12x10136 and wd12x10277. About $17.00 and rack is rolling perfectly. GE wanted 200 for an entire rack, no thank you!
2/21/2023 4:37:26 AM • Danby DDW1805W... • Answered on Feb 21, 2023
Dishwasher stays on drain cycle stuck..
hold reset button in for 15/20 seconds.adrian,,,,,,
1/17/2022 11:43:06 PM • Danby DDW1805W... • Answered on Jan 17, 2022
2answers
Danby ice maker keeps flashing it is out of water but there is water in it
The water flow sensor has a dirty connection. There is an eyelet terminal screw holding down to the electrode, that just needs to be cleaned. Just loosening and tightening the screw a few times and maybe moving the electrode more into the stream fixed mine.
Where the water comes into the ice making tray you’ll see two shiny wire electrodes. When the water enters the tray it crosses the two electrodes telling machine has enough water.
Make sure the connection from the wire is clean, and you can test the machine with the cover off and confirm you fixed it.
The electrode is located under the black plastic cover at the rear right side of the machine.
You can access it by just removing the black plastic cover that holds the door. I took all the stainless steel covers off trying to figure this out.
8/28/2018 10:32:08 PM • Danby DDW1805W... • Answered on Aug 28, 2018
5answers
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
7/1/2018 12:38:12 AM • Danby DDW1805W... • Answered on Jul 01, 2018
3answers
Broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
3/20/2017 10:05:01 PM • Danby DDW1805W... • Answered on Mar 20, 2017
Danby DDW1805W dishwasher won't drain
I had this problem and I had to take the shared drain pipe apart. I found a huge cement-like plug of coffee grounds mixed with flour from bread-making. I removed it all and now the machine drains freely.
8/28/2014 3:49:25 PM • Danby DDW1805W... • Answered on Aug 28, 2014
Can't get the door to latch
I never had this problem but here is what it looks like on mine: There is a spring-loaded "U" shaped tongue jutting out at the top which is all the way down: ee61a44b-0405-4fd5-80c9-dfa0e852ccc6.jpg It can be pushed up and then it goes back down when released: 51912ccd-decf-4a6d-a32d-d478759a9a3f.jpg It fits into a cheap plastic white socket on the door: e283aa5c-f299-40a5-80dc-e2ebc721c1c7.jpg I don't know if that is movable or not but it is so cheap and flimsy I don't dare test it. My guess is that your tongue is stuck in the upward position. You said the center. I would try pushing it all the way down. You may just need to lubricate its hinge so it goes down automatically. It may have dried out. Hope this helps.
8/12/2014 6:30:41 PM • Danby DDW1805W... • Answered on Aug 12, 2014
0answers
Where can i get a perkins 4107 wiring diagram?
try the manufactures website
5/10/2014 11:06:45 AM • Danby DDW1805W... • Answered on May 10, 2014
2answers
I have a Danby countertop dishwasher.
You may be able to find your answer at the link below:
http://www.retrevo.com/support/Danby-DDW1805W-Dishwashers-manual/id/886dj686/t/2/
4/2/2014 11:58:03 PM • Danby DDW1805W... • Answered on Apr 02, 2014
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
101 questions posted
Top Danby Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Danby Dishwashers
  • Danby Dishwashers
Most Popular Question
portable danby stuck drain cycle
  • Dishwashers
