20 Most Recent
Panasonic NN-H965 Microwave Oven Questions & Answers
This is actually a one-year-old
Inside is a screen which sometimes arc. These are normally available from the dealers and is not very expensive. Microwaves are dangerous and repairs are better left to trained people.
1/3/2018 11:15:50 AM •
Panasonic...
Answered
on Jan 03, 2018
My Panasonic NN-SD297 microwave is
To deactivate the DEMO MODE on your Panasonic microwave, just press the CLOCK button on the control panel 3 times.
If you were successful, then the display panel will go blank and will no longer display the 'DEMO MODE PRESS ANY KEY' message.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
3/17/2015 1:05:18 PM •
Panasonic...
Answered
on Mar 17, 2015
How to remove and replace microwave door key
You must remove the inside plastic door liner that surrounds the glass. It just snaps into place so usea small flat blade screw driver to pry it out. You can then replace the door key.
If the spring has detached from the door a the outer door must be replaced.
1/19/2015 6:35:15 AM •
Panasonic...
Answered
on Jan 19, 2015
How to reset microwave
there is no reset function to look over, check safety interlock door switch, Has lamp & control Display lit?
8/19/2014 5:47:11 AM •
Panasonic...
Answered
on Aug 19, 2014
What do i do about the tirntable not turning
first open door an take a good sniff see if you smell any burnt smell it could be a burnt out drive motor or a broken wire there are repair shops that do that DO NOT TRY AND FIX YOUR SELF read the warning panel
7/11/2014 12:31:41 AM •
Panasonic...
Answered
on Jul 11, 2014
How do i change the turntable motor on a sears 72163259301
Go to the bottom of the oven - they have several side-by-side holes that when you cut through the little bit of material between the holes, allows you to create your own door - inside should be your turntable motor - Again this is a standard type location - Commercial units may not have turntables, but the 'stirrer' is instead located below the plain table on which you rest your food
5/14/2014 5:21:29 AM •
Panasonic...
Answered
on May 14, 2014
How do i change the turntable motor on my sears microwave
Most microwave ovens have a door on the bottom of the oven to access the turntable motor - I am not familiar with a Sears in particular, but if the door is not already cut free and held with a screw, it could be like a Panasonic Microwave whereby you have to cut through side-by-side holes to create your own door on the bottom - then you should be able to access the motor and remove it's screw(s) and wires - It the door is one you had to make, then they will have it created so you have tabs to line up, but you need a screw to hold it in place
5/14/2014 5:18:34 AM •
Panasonic...
Answered
on May 14, 2014
H98 error
H95, H97, H98 or
H99 mean that there's a problem with your inverter,
magnetron, or digital programming circuit.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
1/30/2013 9:39:58 PM •
Panasonic...
Answered
on Jan 30, 2013
Panaonic nn 1000 gs 597 no working microwave
follow this steps and fix it. God bless you
No power to outlet (overload or fault in microwave or other appliance).2. Blown main fuse - likely due to other problems.3. Open thermal protector or thermal fuse.4. Defective controller or its power supply.5. Clock needs to be set before other functions will operate (some models
1/23/2013 5:41:43 PM •
Panasonic...
Answered
on Jan 23, 2013
Hp96
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test. If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.If there is heating without any issues, you can use the microwave safely
6/14/2011 4:39:01 AM •
Panasonic...
Answered
on Jun 14, 2011
