20 Most Recent Sennheiser Evolution G2 100 Series UHF Handheld Microphone System (A) EW135PG2A Microphone Questions & Answers
I have an e100 g2. I'm getting no sound. Have
We'd need to know more about the receiver than the mic, since it's the receiver that is muted. Muted means NO SOUND.
5/12/2023 10:09:25 PM • Sennheiser... • Answered on May 12, 2023
Trying to replace a cracked end cap on a Sennheiser Evolution g2 100 wireless mic
Contact your local service center directly or online here: https://en-us.sennheiser.com/service-support-contact-center helpful-hhkqfx2w2zkuwwpsab3b1hzw-3-0_20.png
2/7/2018 5:26:59 AM • Sennheiser... • Answered on Feb 07, 2018
I have AKG pt 60 wireless lavalier mic with AKG sr60 receiver where the mute is always on. I tried every possible channel, but the mute is still flashing. Help me guys!
It sounds as though the frequencies are not matched up. Check the owners manual. This has happened to me a few times.
4/3/2015 7:36:23 PM • Sennheiser... • Answered on Apr 03, 2015
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows. RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again. Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
3/4/2014 9:19:24 PM • Sennheiser... • Answered on Mar 04, 2014
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
4/24/2010 6:33:35 AM • Sennheiser... • Answered on Apr 24, 2010
2answers
I have 3 sennheiser ew100 G2 handheld mics which
You can send them to Pro Line Music
490 Lincoln Highway
Fairless Hills PA. 19030
215-736-8055
It will cost $65. for evaluation + parts+ aditional time past 1hr. + return shipping.
4/17/2010 5:04:19 PM • Sennheiser... • Answered on Apr 17, 2010
I have a Sennheizer evolution g2 transmitter and
It got nothing to do with the frequenty.
You can adjust the microphone gain in the handheld-menu. You can also adjust the receiver-output gain in his own menu.
Good luck,
Gerard
1/31/2010 9:46:03 AM • Sennheiser... • Answered on Jan 31, 2010
All four hand held systems failed during a performance
Hi kb
That is an odd encounter, and most probably one of the R.F.I. kind. Radio Frequency Inference can be caused by many things. Sometimes it can be a nearby piece of equipment creating that much interference, that the mics could not operate. It may have been a spurious mobile radio transmitter as used with two way radio for the cops, ambo's, firies,or even a nearby Cab!! Some times faulty light dimmers can also spray RF.
To what ever end, the fact that 4 mics went down together is indicative of an external problem, and being radio mics, it would have been radio interference.
The only other thing to check is that they are UHF. there are many VHF mic systems still about, but these frequencies are now being used as part of the soon to be introduced digital TV transmission. Best check that they are UHF, The VHF type have actually been illegal for a number of years Hope this info has helped you understand your problem. I am happy to answer any questions you may have. Cheers
regards
robotek
12/19/2008 1:54:27 AM • Sennheiser... • Answered on Dec 19, 2008
Sennheiser RS 175 TV headset has green lit power light blinks on and off. And headset doesnt have any volume. Help!
If your Sennheiser RS 175 TV headset has a green lit power light that blinks on and off and doesn't have any volume, here are some troubleshooting steps you can try:
  1. Check the batteries: Ensure that the batteries are charged and inserted correctly into the headset. You may also want to try replacing the batteries with fresh ones.
  2. Check the audio source: Make sure that the audio source is turned on and the volume is turned up. You may also want to try connecting the headset to a different audio source to see if the problem is with the source.
  3. Check the audio cable: If you are using an audio cable to connect the headset to the audio source, make sure that it is plugged in securely at both ends.
  4. Reset the headset: Try resetting the headset by turning it off, unplugging the transmitter from the power source, waiting for a few minutes, and then plugging the transmitter back in and turning the headset on again.
  5. Check for interference: Make sure that the transmitter and headset are not too far apart or obstructed by walls or other objects. Also, ensure that there are no other devices nearby that may be causing interference.
If none of these troubleshooting steps work, you may need to contact Sennheiser customer support or take the headset in for repair.
2/24/2023 9:04:37 PM • Sennheiser Audio... • Answered on Feb 24, 2023
HOW DO I CONNECT MY SENNHEISER RS 120 HEADPHONES TO MY LG UHD TV MODEL 55UK63
Hello Mike, your LG TV, does not have a headphone output, it only has optical fiber audio output the options that I suggest are, 1) Connect the optical fiber output of the LG, to an AV receiver, that has said input and place the headphones in this equipment, 2) Buy an optical fiber to audio converter by RCA L and R and this is connected to a headphone amplifier I send you links to the products that are sold in my country I hope you solve your concern Greetings Franco Dosil This is the headphone amplifier This is the optical fiber to audio converter by RCA L and R Hola Mike, tu TV LG, no cuenta con salida de auriculares, solamente tiene salida de audio por fibra ?ptica las opciones que te sugiero son, 1) Conectar la salida de fibra ?ptica del LG, a un receptor AV, que cuente con dicha entrada y colocar los auriculares en este equipo, 2) Comprar un conversor de fibra ?ptica a audio por RCA L y R y este conectarlo a un amplificador para auriculares Te env?o links de los productos que se venden en mi pa?s Espero logres resolver tu inquietud Saludos Franco Dosil este es el amplificador de auriculares Este es el conversor de fibra ?ptica a audio por RCA L y R This is the headphone amplifier Este es el amplificador de auriculares https://articulo.mercadolibre.com.ar/MLA-784156450-behringer-ma400-ultra-compact-monitor-auricular-amplificador-_JM This is the fiber optic to analog audio converter Este es el conversor de fibra ?ptica a audio por RCA L y R https://articulo.mercadolibre.com.ar/MLA-707192478-convertidor-audio-digital-toslink-optico-coaxial-a-rca-nuevo-_JM
9/8/2022 8:51:53 AM • Sennheiser Audio... • Answered on Sep 08, 2022
I am have trouble disconnecting my sennheiser ski 100 G3 from my microphone - what is the secret
Hello Timothy, the microphone has a 3.5 mm connector, which has a thread, you must unscrew this thread and you should be able to exit Discuss the type of connector you have I hope you can solve the problem Greetings Franco Dosil Hola Timothy, el microfono tiene un conector de 3,5 mm, que tiene una rosca , debes desenroscar esta rosca y tendria que poder salir Comenta el tipo de conector tiene Espero puedas resolver el problema Saludos Franco Dosil https://assets.sennheiser.com/global-downloads/file/8949/SK_100_G3_Manual_12_2016_EN.pdf
6/21/2019 5:59:21 PM • Sennheiser Audio... • Answered on Jun 21, 2019
Sennheiser HDR 100, wires deteriated on transmitter. Can the transmitter be replaced?
Hi David, comment that cables are wrong in the transmitter, to try to find the best possible solution I wait your answer Greetings Franco Dosil Hola David, comenta que cables estan mal en el transmisor, para tratar de encontrar la mejor solucion posible Espero tu respuesta Saludos Franco Dosil https://www.fullcompass.com/brand/sen-sennheiser/replacement-parts https://en-us.sennheiser.com/accessories http://www.hifiheadphones.co.uk/spares-accessories/sennheiser-spares.html?currency=EUR&dir=desc&limit=5&mode=list&order=name
6/7/2019 5:33:17 AM • Sennheiser Audio... • Answered on Jun 07, 2019
SENNHEISER EW100 G2 wireless microphone RECEIVER with lcd flashing all the time. Not functional.
Hi Edgar, it is important that the receiver works, because there is a dialogue between the transmitter and the receiver to confirm that they are on the same frequency, that is why the transmitter is blinking, you should repair the receiver and look for the frequency or channel that the transmitter is found and it will stop flashing Hola Edgar, es importante que el receptor funcione, porque hay un dialogo entre el transmisor y el receptor para confirmar que est?n en la misma frecuencia, por eso es que el transmisor esta titilando, deber?as reparar el receptor y as? buscar la frecuencia o canal que se encuentra el transmisor y este dejara de titilar
4/15/2019 5:43:03 AM • Sennheiser Audio... • Answered on Apr 15, 2019
12 questions posted
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sennheiser Audio Players & Recorders
Most Popular Question
all four hand held systems failed
  • Audio Players & Recorders
