20 Most Recent
Danby DWM99W Top Load Washer Questions & Answers
I have a new Danby washing machine but leaks
you have a new washer so why not get the service agents out under warranty to fix the faulty machine
ask why there was water in a new machine as that indicates not new but second hand
Won't wash
I didn't realize that you have to let the faucet run the entire duration of the wash cycle. But that was the problem.
Washer Won't spin & smells burning when it goes on spin
Hi there.I think it could be that when the belt was changed the bolt wasnt tightened onto the flat side of the spindle.I am talking about the small pulley that comes off to replace the belt.It has one flat side in which the bolt needs to be otherwise it might just spin because the laundry weight. Quick question I have this machine and it needs a replacement belt.I cant find one anywhere!!!!Where were you able to find one???? Good Luck
Doesn't drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
