20 Most Recent
Compaq Diskette Drive / Cd-Rom Cable Deskpro 4100 5100 Minitowers Presario 900 9200 9500 9600 Prolin... Questions & Answers
Windows XP OS
1st use the old CD and format the partition and then try the new OS.
Help
If your machine should have the XP key on a tag on it. If you no longer have the tag, the restore CD that came with the machine often (but not always) will re-install without a key. On the other hand, if you have a working installation and need to recover your current key, you can get a FREE utility to do that from:
http://www.nirsoft.net/utils/product_cd_key_viewer.html
New comp
Which OS is running on your computer.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
