20 Most Recent
Zapf Baby born 778166 Questions & Answers
Zapf Creation Baby Born Doll D-96472
is this a doll that eats and (poops?)..the mouth is an upper hole and the lower hole should be a spot under the main body..if food particles are inside the dolls' body may need a tool like the old water pic flossing macine to clean it out..it is possible to redo a small garden sprayers tip/nozzle to accomodate cleanout of this doll..catch is to find some sort of presurized hose tip to put in the mouth cavity to clean out the body of residue..if that is what is happening..
My grandaughters baby born doll won't close his eyes when you put dummy in. you can manually close the eye so it isn't stuck. any ideas how to fix this
We had the same problem a few months ago. We even bought another dummy, but it did not help. Then we found the solution by ourselves. My daughter took her baby born to her bath and we put her into the water. Then I pressed ******* the face for water to go inside through the eyes many times. After I did it a few times with a lot of water the doll start to close and open her eyes again with her dummy. I do not know for what reason but eyes start to stick inside. I believe it may be because of the food, or dust. Maybe not. However from my observations it happen when we did not bathe her for a long time.I hope it helps.
