20 Most Recent Comfort-Aire HD-301 Dehumidifier Questions & Answers
When I emptied the buckey a small red part fell
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
5/27/2011 5:26:34 PM • Comfort-Aire... • Answered on May 27, 2011
It runs for a few seconds and then shuts off
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
8/29/2010 9:28:00 PM • Comfort-Aire... • Answered on Aug 29, 2010
Unit will not power up.
below are the things you have to look out for:
Ensure that the dehumidifier is getting power from the home by checking the power cord, circuit breaker switch, and fuse.
Check the water level in the tank if your dehumidifier runs for a prolonged period of time or does not switch on at all. If it is empty or low, change the dehumidifier's air filter. If the tank is full, empty the water and try the dehumidifier again. Replace the float switch if the dehumidifier will not turn on after the tank is emptied. If the dehumidifier still does not work, call a repairman to check the refrigeration system.
Inspect the fan and motor assembly if there is no air coming out of your dehumidifier. Rotate the fan by hand to ensure that it is not stuck and look for cracked or damaged blades as you go along. Check the motor with a circuit tester and replace it if it fails.
Examine the coils in the back of the dehumidifier for signs of frost. Frost makes the dehumidifier unable to pull any additional moisture out of the air as it is passed over the coils. Turn off the unit to allow the coils to defrost before attempting to use it again.
Good luck.
8/1/2010 1:13:26 PM • Comfort-Aire... • Answered on Aug 01, 2010
I'm looking for a float shutoff for Comfort-Aire BHD-651 Dehumidifier.
https://www.amazon.com/HEAT-CONTROLLER-Comfort-Aire-Pint-Dehumidifier/dp/B000RE6X28
4/13/2020 5:30:11 PM • Comfort-Aire... • Answered on Apr 13, 2020
Full light stays on always
Don't know your model specifically, but most dehumidifiers have a float that shuts the system down when the tank is full. Maybe the float is not going up and down like it should. With the power off and the tank out, see if the float is descending like it should when the tank is out. Popping it up and down a few times might solve the problem.
1/22/2015 8:47:17 PM • Comfort-Aire... • Answered on Jan 22, 2015
What does the check filter light indicate?
Don't know your model specifically, but you might want to check the air filter at the front. It could be totally clogged up and no air can pass through for the system to work.
1/22/2015 8:39:08 PM • Comfort-Aire... • Answered on Jan 22, 2015
0answers
0answers
0answers
The bucket full light keeps flashing that it's full but it's not
The float in the bucket might have to be ajusted.
1/2/2013 8:07:24 PM • Comfort-Aire... • Answered on Jan 02, 2013
Comfort-Aire HD-301 Dehumidifier Logo
11 questions posted
Top Comfort-Aire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Comfort-Aire Dehumidifiers
Most Popular Question
when emptied buckey small red part fell
  • Dehumidifiers
