20 Most Recent Arris SURFboard SBG900 Wireless Router (DHSBG900) Questions & Answers
Can't log into 192.168.0.1
The article I read suggested 192.168.100.1 admin (no capitals) motorola (no capitals) And no need to get your breathing rates high in case you have changed the username/ password of Motorola SBG900 and forgot them, as you can just reset the Motorola SBG900 router by press-and-hold the reset button with a straightened paperclip for about 15 seconds. http://modemly.com/Motorola-SBG900-router-setup
11/9/2018 3:22:57 AM • Arris SURFboard... • Answered on Nov 09, 2018
Bridging a Motorola SBG900 to a Speedstream 4200
You can't use the Motorola SBG900 for that. The only way it might work is if the Motorola SBG900 had a 4-port Ethernet switch built into it.
12/22/2017 12:52:24 PM • Arris SURFboard... • Answered on Dec 22, 2017
Cant access router admin page
What URL are you using to get to the admin page? It is possible the Arris has been configured to only allow wired connections to the admin page. You may need to connect an Ethernet cable between your computer and the modem. If you are connected wirelessly, what is your default gateway? This should be the URL you're attempting to connect to for the admin page.
11/3/2017 8:39:00 AM • Arris SURFboard... • Answered on Nov 03, 2017
0answers
2answers
How can I unlock my router? I forgot the password
Ok I found two support links for you.The first one will give you a phone number and the other is for email support,they are for your router support.You will be able to gain access after giving them some required answers.(its not hard or time consuming)
Here is the phone number 1-877-466-8646 note not a free number! hope this has helped
http://broadband.motorola.com/consumers/support/phoneSupport.asp?productID=sbg900
http://broadband.custhelp.com/app/answers/list
4/3/2017 10:54:02 AM • Arris SURFboard... • Answered on Apr 03, 2017
How do I torn off fire wall on my time warner cable ARRIS wifi router
See step 2; it's a matter of just clicking the firewall protection to OFF, from the "set up firewall protection" menu. Set Up Firewall Protection You can set up firewall filters and firewall alert notifications on your wireless home network. You can also block Java Applets, Cookies, ActiveX controls, popup windows, Proxies, and website access. See Protection Level for more information. To set the firewall protection level: 1. From any screen, click the Firewall-Protection Level menu link or click the Firewall menu button on the SBG6782-AC Main Menu and then select Protection Level. Figure 17 - Firewall Protection Level Screen 2. Click the Firewall Protection Setting drop-down button to select the firewall protection level. Possible values: Low, Medium, High, or Off Note: Selecting Off will disable firewall protection on your home network. Your computer(s) and other Ethernet-enabled devices on your network will be at risk for possible attacks from viruses and hackers. 3. Select each Web filter that you want to set for the firewall and then click Apply.
12/26/2016 12:04:42 PM • Arris SURFboard... • Answered on Dec 26, 2016
2answers
My laptop diagnosing that I have to reset my
hi
there is apinhole on back of router -- use pin or paperclip and depress it for 3-5 seconds, while the router is powered on
6/13/2016 12:52:17 PM • Arris SURFboard... • Answered on Jun 13, 2016
Changing security key on my modem surfboard wireless sbg6580
Use the default user name and password to login... then you can go to wireless tab and chamge the WPA key to whatever you want.
9/23/2014 4:58:32 AM • Arris SURFboard... • Answered on Sep 23, 2014
How to change motorola sbg6580 router nat to open
We recommend you contact ARRIS for Consumers Mark Motorola Support
8/28/2014 3:18:55 AM • Arris SURFboard... • Answered on Aug 28, 2014
Surfboard motorola parental control
Contact ARRIS for Consumers Mark Motorola Support
8/28/2014 2:46:08 AM • Arris SURFboard... • Answered on Aug 28, 2014
2answers
Sbg9000 wireless surfboard
At this time, no. Only your cable/DSL provider would be able to do it. Unless your into some hardcore scripting. Hope this helps!
8/25/2014 1:47:51 PM • Arris SURFboard... • Answered on Aug 25, 2014
What is my Motorola password?
It might be written on a sticker on the underside of the unit.
7/23/2014 1:33:18 PM • Arris SURFboard... • Answered on Jul 23, 2014
How do I find wps button on Netgear WNR834B
The Netgear WNR834B does not support WiFi Protected Setup (WPS). You can follow the documentation in the manual to setup WPA-PSK (Pre-Shared Key) and use the key to add devices to your wireless network. Manual: http://documentation.netgear.com/wnr834b/enu/202-10171-01/pdfs/FullManual.pdf
6/24/2014 5:46:20 PM • Arris SURFboard... • Answered on Jun 24, 2014
Where is the wps button on my netgear08 router
Hello, If I am not mistaken, if you are facing the router the WPS button should be located on the right side, it is easy to miss because it is a recessed button. Look closely! Thanks, -Seth
5/18/2014 12:03:24 AM • Arris SURFboard... • Answered on May 18, 2014
Thomson 585 v6 we're is the wps button.
Hello: According to the manual, the Thomson ST585v6 doesn't support WPS. You will have to record the wireless passphrase and enter it manually in the device you're trying to install on the network. Manual: http://downloads.thomson.net/telecom/documentation/ST585v6/R82X/SetupUserGuide/PDF/ST585-v6_SetupUserGuide_en.pdf
5/3/2014 2:23:52 PM • Arris SURFboard... • Answered on May 03, 2014
Does the motorola surboard sbc6580 modem have phone connetion
Hello: Neither the SBG900 nor the SBG6580 have a phone jack. A cable modem with a phone jack is called an eMTA (Embedded Multimedia Terminal Adapter: Cable modem Wikipedia the free encyclopedia.) Most cable companies will only have one alternative to their own equipment when it comes to eMTAs. For example, Comcast only works with the Arris 722G: Customer Owned Arris 722G FAQ Comcast Help and Support Forums, and they'll insist that it can only work if you bought it from Best Buy. If you wanted to keep your SBG900 or SBG6580 and have VOIP phone service, look into a service like Ooma.
5/3/2014 2:18:34 PM • Arris SURFboard... • Answered on May 03, 2014
Where is WPS button
canon mx459 printer instructions say hold down WPS button, can't find such button, where is it please?
4/6/2014 4:38:56 PM • Arris SURFboard... • Answered on Apr 06, 2014
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
457 questions posted
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Arris Computers & Internet
Most Popular Question
trying connect canon mg8220 printer
  • Computers & Internet
