20 Most Recent
Compex NetPassage 27G Wireless Router (NP27G) Questions & Answers
Hi, I forgot the password
Hello
First unplug the power from the router.
Next there should be a small reset button maybe in the back.Hold it in for 1 min.
Plug router back in.
Once your back running open your browser and type.192.168.1.1
hit enter.
Then you will use admin as username and the word password as the password.
once in the router go to the security page and change the username,write it down somewhere.
Router will reboot once your done.
11/26/2010 12:58:14 PM •
Compex...
Answered
on Nov 26, 2010
I want np25g router
Find the reset button on the router and depress it for about 30 seconds. This should clear the password. It'd usually recessed and not always easy to find, so you may need something (non-metallic), like a tooth pick. Look closely and you should see the word "reset".
Hope this helps!
11/1/2010 6:17:22 AM •
Compex...
Answered
on Nov 01, 2010
How to reset router password???
Reset of only password is not possible how ever you can reset the box which will erase all the configuration and loads itself with default settings.
there is a tiny black button at the buttom of the device.
Press that button and dont release that , and power ON the device.
The Power LED will glow and then the sys LED will blink slowly and then rapidly. then release the black tiny button and wait for 2 minutes for the device to boot up.
Then you can login to the device with the default credentials.
10/31/2010 1:49:03 PM •
Compex...
Answered
on Oct 31, 2010
Picked up a Compex NetPassage 27G at a yard sale
Hi
start by trying these:
Default
IP for all Compex's Routers/ APs/
Client Adapters:
192.168.168.1
Default IP for all Compex's Modems:
192.168.1.1
Default IP for all Compex's Switches:
192.168.100.128
Default Password for all Compex's
products:
Password
Default User ID
for Compex's modem:
Admin
alternatively most router will have a reset button that's usually behind a little hole in the back or at the bottom of the unit. inspect the device carefully and introduce something sharp (that won't break) through that hole while the unit is powered and press for 30 to 60 seconds, this is usually how devices are brought back to factory defaults. if this does not work it's like the device is defective and you may want to get your money back!
hope that helps!
5/6/2010 2:29:40 PM •
Compex...
Answered
on May 06, 2010
How to disable router password
Hi, why do you want to disable router password?
It is part of your security so sobody else can access it.
What happens if someone want to connect to your router or alter any settings, they could do this then lock you out of it while sensitive information is being stolen from your pc.
LEt me know what help you are really looking for, maybe i can help with what problem it is you have.
1/23/2010 1:44:03 PM •
Compex...
Answered
on Jan 23, 2010
Install CD of compex NetPassage 26G is lost
This router is at least 5 years old, and it does not support the more-secure WPA protocol. On that basis, I would "trash" it.
I checked the COMPEX web-site:
http://www.cpx.com/download.asp
and there is no mention of the '26G', although the '27G' is listed as a "legacy" product.
So, spare yourself a lot of wasted time -- go to the nearest "Boxing Day/Week" big-box store, and buy a new router, with new features, like 'Wireless N' and 'WPA2' support, and install it.
12/27/2009 2:53:41 PM •
Compex...
Answered
on Dec 27, 2009
Need to re-setup my router.
Try to hard reset the router by pressing the reset button at the back of it. Hold it down for 30 seconds then unplug the power for 30 seconds. Reconfigure it
6/1/2009 5:47:28 AM •
Compex...
Answered
on Jun 01, 2009
How can i set passkey
Just reset the router , button on back
and use the default factory password to login
5/15/2009 5:51:51 PM •
Compex...
Answered
on May 15, 2009
Problem with power
Since I don't know the exact circumstances of your power loss, here what I am guessing based on that you wrote.
This may be because the power does not come back cleanly after the power failure. Unfortunately, there is nothing much you can do about it. Since your router does work correctly after you manually reset it, the power supply seems to be fine.
If you have many power failures and find this situation to be annoying, you should look to buy a UPS (Uninterrupted power supply). This kind of devices have a battery that will ensure a clean power output when running, powering up and shutting down. It will protect you from interruptions and voltage fluctuation. You may also benefit from connecting you computer to a UPS because it will keep it running for a couple of minutes after a power failure to allow you to save your work and may also shut it down cleanly automaticaly.
2/23/2008 7:25:49 PM •
Compex...
Answered
on Feb 23, 2008
