20 Most Recent Foxconn (945G7MA-8KS2) Motherboard Questions & Answers
Foxconn 945P7AA Series
ask a real quesstion foxconn shut down , DIY mobo sales. 2012. so the that lil' bummer.
5/13/2022 11:52:17 AM • Foxconn... • Answered on May 13, 2022
I need to be able
OLD POST CUBASE no version told a travesty that.!no answers, but not told you it is" GPU hardware acceleration."use the word GPU,.as CPU has "speed step and more" but you can only do that if the GPU card has it like my GTX1650 has.there is no intel 945 chip set , support, at all, now, or then 2017zero not even w7 so says intelwhy not ask CUBASE what they need ,they wrote the app and complied it and only they know this. ask for minimum system spec. just all games do.the OS must support it, seen herehttps://www.avs4you.com/blog/hardware-acceleration/this is German made softwaremy guess is w10 64bits ??? must I guess????iGPU can not be removed , in PC 2010 or newerbut yours is the useless relic , CPU, GPU. 945G7MA-8KS2Id say CUBASE hates P4 pentium 4 from, 2002.that mobo is pure relic junk at $1 value usedand maker ended support in 2019 foxconn./4GB ram min.v11 min, Intel Core i series (i3 up, not p4 ever)not core2, either. 2009 or older of any kind.v9 samev8 ,core2 min, and up. sure.v7 same core2. lower ver I don't know.yes, in BIOS, most PCs have this, iGPU1: auto2: IGPU aka, onboard or on CPU die)3: PCIe, GPU.set it as you like and most PCs made on earth do not have full BIOS manuals, (asus, excepted)some or none is par.i stop here googling this for you.you can not turn off GPU acceleration because1: not used. by CUbase2" nor was it there in 2002, only dream there if that.windows should say, NOT THERE, only. gray means that.this feature is used extensively in BIT coin, mining.and for of my dvd/br DISK DECRYPTORSand more and only to modern cards do this. $$$$my guess not reading the cubase MANUAL IS THE PROBLEM ONLY, NOT READING PAGE, MIN SYSTEM AND NOT READING PAGE ON HARDWARE ACCELERATION CHOICES.
5/11/2022 3:24:48 PM • Foxconn... • Answered on May 11, 2022
0answers
8ks2h sound driver
Be the first to answer 11/4/2013 7:13:09 PM • Foxconn... • Posted on Nov 04, 2013Be the first to answer
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
2/23/2012 6:11:22 PM • Foxconn... • Answered on Feb 23, 2012
When i start computer with only mother or
make sure the leads from motherboard to hard drive are good and securely seated with no dust in the connections
if its a 40pin ide it will be the first to fail
hope this helps
10/23/2011 6:32:07 PM • Foxconn... • Answered on Oct 23, 2011
Can i see all the information about n15235 with
Hi, you can download a manual and drivers here:
But there is 2 different models of your mainboard.
http://www.foxconnsupport.com/download.aspx?models=en-us0000158&category=C000000001&series=en-us0000002&keywords=&sort=Drivers
Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
http://www.foxconnsupport.com/download.aspx?models=en-us0000191&category=C000000001&series=en-us0000002&keywords=&sort=Drivers
Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775) - 533/800MHz front side bus (FSB) - Single channel DDRII 533 / 400 x2 DIMMs - 1 x AGP 8x, 3 x PCI - ATA x 2 + Serial ATA x 2 w/ RAID - 5.1 channel Audio, AC'97 interface (Realtek) - 10/100M LAN (Realtek) - 8
9/16/2011 2:38:32 PM • Foxconn... • Answered on Sep 16, 2011
W4e
Hi, download drivers and a manual here:
http://www.foxconnchannel.com/product/motherboards/detail_overview.aspx?id=en-us0000024
You will maybe have to unzip the file
before installation.
9/10/2011 9:39:22 AM • Foxconn... • Answered on Sep 10, 2011
The foxconn driver cd INT-915
SimpleGo to device manager
9/2/2011 10:14:16 AM • Foxconn... • Answered on Sep 02, 2011
I need a driver high
Hi, you can try this driver from here:
http://download.cnet.com/Audio-Realtek-ALC655-AC-97-AUDIO/3000-2110_4-168843.html?tag=rb_content;contentMain
You can also try to run windows update.
Or you can try the foxconn site:
http://www.foxconnsupport.com/download.aspx?models=&category=C000000001&series=&keywords=945g7
Or you can add a soundcard in the PCI slot compatible with windows 7.
Hope this was helpfull.
8/15/2011 6:38:07 PM • Foxconn... • Answered on Aug 15, 2011
I have an old Pachard
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc hope this helps or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html if you need more help with this post a replyhope this helps
8/13/2011 7:37:10 PM • Foxconn... • Answered on Aug 13, 2011
My dell internet connector or
Hi.
The cable you need to get you back on the internet is called an Ethernet cable or RJ-45.
Regards.
7/16/2011 4:36:53 PM • Foxconn... • Answered on Jul 16, 2011
3answers
I had to reload WINDOWS
Hello and Welcome to FixYa!
Kindly trace your PC's brand and model, forget about the Board its complex. Just tell me the Brand and Model of your PC and I'll find the sound driver for you. It will definitely be available online.
Waiting for your response..
Concerned, Nooh.
5/28/2011 12:25:11 PM • Foxconn... • Answered on May 28, 2011
2answers
Il have a motherboard with
Hello Jorn,
Please download the Sound drivers from the link provide below :
http://www.foxconnchannel.com/support/downloads.aspx
When the web page opens please choose the model name, series and type in the drop down menu.
After selecting all the option page will dispaly the required Sound drivers.
5/6/2011 9:20:17 AM • Foxconn... • Answered on May 06, 2011
The Bus Interface of PCI-e 16X graphics cards
could you please tell us the problem you are facing with your pcie port
4/13/2011 11:01:38 PM • Foxconn... • Answered on Apr 13, 2011
Foxconn (945G7MA-8KS2) Motherboard Logo
94 questions posted
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Foxconn Computers & Internet
Most Popular Question
see all information about n15235
  • Computers & Internet
