20 Most Recent Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Questions & Answers
go to the web site of board get the manual then check the other case wiring then make the changes you need to make.
Foxconn WinFast... | Answered on Oct 26, 2013
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Foxconn WinFast... | Answered on Jun 16, 2013
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000557
Click on the Tech Support tab, for Drivers
Need guidance in downloading AND installing, post back in a Comment, or Reply; at end of solution
Regards,
joecoolvette
Foxconn WinFast... | Answered on May 07, 2013
Hello you can download the right driver here:
http://www.foxconnsupport.com/download.aspx?models=en-us0000129&category=C000000001&brand=en-us0000002&Series=en-us0000006&chipset=en-us0000058&keywords=&sort=
If i am wrong by the mainboard model, enter the right number in the seach field.
Make sure your speakers, is connected the green outlet, and check that the volumen is not turned down low, or muted.
Good luck
Foxconn WinFast... | Answered on Jan 27, 2013
google translated to english for someone
I want to
add a video card to my motherboard windfast k7s741mg
Foxconn WinFast... | Answered on Nov 22, 2012
where i can send you the CD copy for sound driver
Foxconn WinFast... | Answered on May 04, 2012
You can find it on the bottom right part of the motherboard below the memory ports. It will be called FP1. It will be the upper 3rd and 4th pin. It may say PSWITCH above it. If you want a diagram, you can find it in the manual at the link listed below:
You will see it under File Downloads. It will be on page 4 of the manual. Hope this helps!
Foxconn WinFast... | Answered on Mar 31, 2012
Hi there.
The memory that your motherboard can take is DDR memory. According to a spec sheet it can take PC2700 (333MHZ) or PC3200 (400MHZ) memory. I hope this helps. If you have a RAM module already in it I would suggest getting one that has the exact same spec.
Foxconn WinFast... | Answered on Sep 14, 2011
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download one
cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
hope this helps you
Foxconn WinFast... | Answered on Sep 12, 2011
As long as it is an ATX compatible power supply increasing the available wattage is not an issue, only meeting MIMIMUM power requirements
You can go to a 500, or even a 750 as long as it has the correct motherboard connections
Foxconn WinFast... | Answered on Aug 03, 2011
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
134 questions posted
Top Foxconn Computers & Internet Experts
Ekse
Thomas F. Schneider
WTF Chuck.....
WTF Chuck.....
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Foxconn Computers & Internet
Most Popular Question
plug in connector power button
  • Computers & Internet
