20 Most Recent
Samsung UN55ES7500 55 Inch 3D 1080p Smart TV LED LCD HDTV Bundle Questions & Answers
I have a Samsung UA55ES 7500 smart TV which will switch on by itself after several hours. What could be the problem
Fault at its main digital board. Start pulse comes from it to the power board at wrong time.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/25/2016 10:20:52 AM •
Samsung...
Answered
on Jul 25, 2016
I have a samsong tv that keeps turning off and on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
4/25/2016 10:23:51 PM •
Samsung...
Answered
on Apr 25, 2016
Inadvertent power shut off on UN55ES7500
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
4/10/2015 1:40:11 PM •
Samsung...
Answered
on Apr 10, 2015
Thin gold lines from top to bottom of tv screen left side
Could be a power supply problem or a moister problem with connections.
I would remove the back panel and inspect the power supply for bulging capacitors, blow the unit out and run a hair dryer around the outside of lcd screen.
1/17/2015 4:35:49 AM •
Samsung...
Answered
on Jan 17, 2015
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
