20 Most Recent LG 60PC1D 60 in. Plasma Television Questions & Answers
The screen is damaged, the only way to fix it is to replace the LCD panel.
LG 60PC1D 60 in.... | Answered on Nov 01, 2017
The tv before,the tv power supply board already have problems and was slowly dying,that why it require u to pushes 5 to 7 times for the tv power supply board to be able to sustance and hold power for the tv.Now the tv power supply board it is alot weaker or already dead.That why the tv dose not power on anymore.The tv power supply board that the board where the tv power a/c cord plug into it.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
LG 60PC1D 60 in.... | Answered on May 10, 2017
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
LG 60PC1D 60 in.... | Answered on Jan 26, 2016
YOUR TV PLASMA IS OLD OR THE CHIPBOARD IS NOT POWERING UP..CONTACT THE ELECTRIC REPAIRER
LG 60PC1D 60 in.... | Answered on Nov 20, 2015
You should have its factory remote control to do a reset to it. There is no other way to get into its service mode, and to make a reset. Contact the authorized service center for LG.
LG 60PC1D 60 in.... | Answered on Feb 26, 2015
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
LG 60PC1D 60 in.... | Answered on Jan 28, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
LG 60PC1D 60 in.... | Answered on Jan 26, 2015
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
LG 60PC1D 60 in.... | Answered on Sep 10, 2014
you replace Y-sus board and maybe Z-sus also if the fuse is blown
LG 60PC1D 60 in.... | Answered on Aug 15, 2014
Contact the authorized service center. A firmware update might be necessary.
LG 60PC1D 60 in.... | Answered on Jul 28, 2014
How do you remove the back panel of a singer futura xl400 ?
LG 60PC1D 60 in.... | Answered on May 26, 2014
Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
LG 60PC1D 60 in.... | Answered on Apr 17, 2014
LG 60PC1D 60 in. Plasma Television Logo
140 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
factory reset lg tv model number 60pc1d
  • Televison & Video
