20 Most Recent LG Flatron L1718S LCD Monitor Questions & Answers
How to remove back panel
To know more about this, you have to download the repair manual to this set. Its disassemble section; will give you all details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there. Disasseble procedure to many popular brand TVs are given with illustrations.
3/26/2014 7:05:26 AM • LG Flatron... • Answered on Mar 26, 2014
2answers
Need to remove back cover of LG Monitor
All he wants to know is how to remove the back and we get totally irrelevant replies e,g, how to swivel the monitor on its stand, ridiculous !
9/3/2013 8:46:15 PM • LG Flatron... • Answered on Sep 03, 2013
How to remove back of monitor
is there a fuse inside a lg monitor
5/13/2013 5:16:36 AM • LG Flatron... • Answered on May 13, 2013
0answers
0answers
Lg l1718s driver
Be the first to answer 12/4/2012 10:50:51 AM • LG Flatron... • Posted on Dec 04, 2012Be the first to answer
My monitor goes for 3 seconds black, every 1 minute
First thing, try to connect the monitor to another CPU and see if its gonna work. If it doesn't, then this might be a capacitor failure. One of the capacitors in your monitor that are responsible for holding up power for proper display is faulty. A faulty capacitor is either bulged(with a hump head) or burst. This causes the monitor to go off a few seconds after you switch it on because the capacitors can no longer hold power long enough for your display. One way to work this around is to take your monitor to a Computer Technician to open it up and probably replace the faulty capacitors
11/15/2011 5:42:40 PM • LG Flatron... • Answered on Nov 15, 2011
LG L1718S monitor comes on
This a power failure normally caused by a capacitor failure. Capacitors in this case might be leaking, barged (instead of a flat head, the capacitor has a barged top). When you switch on the monotr, the capacitors are supposed to hold the power enough for the proper display on the monitor. In your case the capacitor(s) are malfunctioned.That is why they can not hold power for more than 5 secondsSolution:Get a sharp and flat tool and open the monitor (starting from the bottom) working your way round to the top. You will notice finger-like clips that hold the covers together. Once you have opened it, check on the electronic board where you connect the power cable. Notice any barged-head capacitor, or leaking capacitor(s). If you find any, they have to be replaced. Get a Technician to do this for you if you can not.
11/5/2011 10:01:41 AM • LG Flatron... • Answered on Nov 05, 2011
I have a vertical line in my display
You have bad LCD panel and it will get worst with more lines appear.http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/ Basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/ Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/ Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
11/4/2011 10:38:16 PM • LG Flatron... • Answered on Nov 04, 2011
Having a LG Flatron L1718S. In
That means the monitor has a problem with the Capacitors. Capacitors inside your monitor can no longer hold up power long enough for your display. This is so because the capacitors might have been blown. This makes the monitor to go on for about 2 to 3 seconds then it goes off.
The solution is to change the capacitors from the board (the part that you connect he power cable). This must be done by a Computer Technician who will safely carry out the procedure. Open up the monitor, using a flat blade and try to separate the cover with the LCD, starting from the bottom, working your way through around. Before you do anything, check for any burged or any with a black smoked colour capacitors...If you find any, then it has to be replaced
8/22/2011 11:02:55 AM • LG Flatron... • Answered on Aug 22, 2011
0answers
I cannot see a button
It looks like you didn't notice the buttons, there should be three buttons on the right pane of the monitor (vertical and when you look at the monitor, they are on the right-hand side), or at the right side panel, which isn't visible from the front, you have to look at them from the right side. Refer the screenshots below (buttons are highlighted):
Front
Right Panel
Hope this helps, let me know if you need further help.
Good Luck.
Thanks for using FixYa.
6/22/2011 11:03:39 PM • LG Flatron... • Answered on Jun 22, 2011
LG Flatron L1718S LCD Monitor Logo
94 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
installed new windwos windwos 7 need
  • Computers & Internet
