20 Most Recent Biostar K8M800 Micro AM2 Motherboard Questions & Answers
Install windows 7 on k8m800
this is fully covered at microsoft.com all steps. insert install media (dvd or USb) boot it and do as it asks.
5/17/2022 6:15:17 PM • Biostar K8M800... • Answered on May 17, 2022
I have to k8m800 micro
no actual problem told, a vague, do not hot swap and HDD drive for sure IDE 4 pin power or blow up the drive you WILL AC cord pulled from wall for 15min, min then work. or IDE slave jumper set wrong, gee why in the world fool with IDE, use SATA only !!!! The bios must see the HDD or it is bad. cables, gee are $1 used. only 1 cable is problematic in any real shop but if it looks ok and ends not mess most IDE ribbon cables are good. 3M ribbon. well you bought 2 old mobo and they failed, or the died in use after 11 years, 2006 o 2017, why not tell history or when it last worked perfect , I can buy endless mobo sure and and I can hack them ***** with bios updates done wrong 10 ways I sure CAN. bolt dead smacks of not RTM read the manual for sure. NO OS TOLD at all XP the virus magnet 2001 used in 2017/ what? well that depends on the chipset of the mobo and Am2 IS NOT Just one set.of chips it is many. this is old old legacy Nforce chipset that fail if the chipset driver is not loaded first did you RTM first, k8m800 , this mobo manual? and VIA K8M800 too, thus the name above. 2006 sold . chip set pain is so common, then, and forward in time. for VT8237R+ (this is IDE and Sata chip and must have a driver) the rotten VIA makers chip set that as zero support at VIA.com and ITE IT8705<< problem child #2 old. not told you any drive model but uses IDE(PATA) or SATA1 drive. wow so using super relic IDE drive,? 4 pin power , junk drives? from 20 years old.? or 11 years old IDK. most drives that old fail and in odd ways, testing any IDE drive is a super pain and 1 full day to run the diagnostic! NEVER USE IDE. unless unemployed. gee use only SATA drives and the test is 10 seconds labor, ask how. to run smart tests, on any sata drive. step 1 is bios new coin cell battery and turn RAID off the chip above. then the OS installer works. here is the w7 driver, https://www.via-drivers.com/download-VT8237-network-driver-for-Windows7-32bit.html 1: coin cell dead now 11 years old and you expect BIOS not to go made/ why? 2: bios settings wrong for sure disable raid. in bios. ,save , exit. 3: and hdd0 in boot order first or 2nd after DVD 1st.
5/17/2022 2:37:49 PM • Biostar K8M800... • Answered on May 17, 2022
0answers
Driver vga
Be the first to answer 11/3/2013 11:46:22 AM • Biostar K8M800... • Posted on Nov 03, 2013Be the first to answer
0answers
0answers
Hello sir, i am using
Hello download the drivers here:http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=141#dlGood luck
10/20/2012 2:01:21 AM • Biostar K8M800... • Answered on Oct 20, 2012
2answers
Why does memory upgrade for biostar k8m800-mam2 motherboard cause memory error beeps?
I would verify that the memory you're using is actually working properly.Try to boot to the new stick and see if it works.If not, it doesn't work.If it does, you may need to replace the original stick with the same stick that you are trying to use now.Use this site as a guide.http://www.crucial.com/store/listparts.aspx?model=K8M800%20Micro%20AM2&Cat=RAM
1/17/2012 12:43:07 AM • Biostar K8M800... • Answered on Jan 17, 2012
2answers
What do i need to do if the screen tends to look
Try to update driver for display adpter. You can download on this page:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=141
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
1/17/2012 12:24:16 AM • Biostar K8M800... • Answered on Jan 17, 2012
Drivers Are Not Updated My Model number is K8M800
Hi there,You can dowload the drivers for your board at the following site.http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=141hope it helpsregards
7/23/2011 7:41:25 AM • Biostar K8M800... • Answered on Jul 23, 2011
2answers
When my biostar k8m800 micro
try to flash the BIOS
4/1/2011 12:12:41 PM • Biostar K8M800... • Answered on Apr 01, 2011
I want k8m800 micro am2
On this page
you can download drivers for your MB.
3/9/2011 5:36:17 PM • Biostar K8M800... • Answered on Mar 09, 2011
2answers
Just yesterday my computer stopped
For that open back cover of cpu then you can see motherboard. First make sure motherboard is not ground with cabinet cover.Reconnect RAM memory ,Reconnect pci card if any.Also reconnect processor and it's fan. Reconnect both connection to harddrive. Then check. Long beep always because of RAM memory so clean it or try with another ram memory then check. Let me know if you need further assistance.Thanks for using FixYa.
11/11/2010 11:10:28 PM • Biostar K8M800... • Answered on Nov 11, 2010
Yesterday my computer stopped booting. Now all it
make sure the RAM is seated properly
Test or Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your (motherboard to hard drive) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up hope this helps
11/11/2010 6:35:00 PM • Biostar K8M800... • Answered on Nov 11, 2010
How do I disable the onboard video? I am adding
When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then go to advanced option menu in bios then disable on board vga then save settings and exit. Then on board vga disable then you can use your another video card. Let me know if you need further assistance. Thanks for using FixYa,
11/9/2010 5:56:13 PM • Biostar K8M800... • Answered on Nov 09, 2010
Biostar K8M800 Micro AM2 Motherboard Logo
49 questions posted
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Biostar Computers & Internet
Most Popular Question
k8m800 micro am2socket amd athlonx2 500
  • Computers & Internet
