20 Most Recent
HP Pavilion dv9205us Notebook Questions & Answers
What wireless is in a hp pavillion dv9205us
I found there to be several model #'s for the cards but all were broadcam
Mine was a broadcam
mine - AS#: 395261-001
mine - SPS#: 407159-001
It has a sticker on it saying replace with HP Spare
I got information from HP
Secondary hard drive for dv9205us
You may install a hard disk drive (HDD) or solid state drive (SSD). Regardless of which you choose, it must have a SATA connection. After installing the drive, be certain the BIOS of the notebook sees it and you should be good to go.
How to switch the microphone in hp pavilon dv 6000
What OS are you using ? XP: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/langbar_speech_mic_turn_onoff.mspx?mfr=trueWIN 7/ VISTAhttp://www.thetechrepo.com/main-articles/509-how-to-change-microphone-settings-in-windows-vista7
No puedo usar my camara gratis
Ve al panel de control y vea si su camara esta en la carpeta.De no ser asi vaya a :1-MyComputer 2-right click 3-Manage 4-Device amnagery corrobore que el driver de la comara este al dia.
I'm sure this is a
Hello.
Could be a power issue.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
My Hp Dv9205us adapter wont
does it have a cardbus slot then you can just push a wireless card into it or use a wireless dongle or tell hp you want a replacement
Hp dv9205 wireless switch went out dont work what
Depending on what operating system you have you can manually enable your wireless..
Google xp, vista, or windows 7 and add to it..enable wireless and you will get the instructions to enable the wireless without the switch.
Try it like this if you have xp
" Windows xp enable wireless "
COMPUTER WILL NOT BOOT. GOES OFF AND ON?
format the hard disk using a boot able cd
or
if you have install a new antivirus then press F8 while booting and boot in safemode and uninstall the antivirus
and boot it in normal mode. if that does not work then simply format the laptop
