20 Most Recent
Olympus Stylus 750 Digital Camera Questions & Answers
I need to take pictures
TRY TAKING PHOTOS SETTING THE THE CAMERA IN THE NIGHT MODE. THIS ALSO WILL NOT GIVE YOU GREAT PHOTOS AS THIS IS A ENTRY LEVEL CAMERA. YOU REQUIRE A PROFESSIONAL CAMERA LIKE DSLR TO TAKE SUCH PHOTOS.
REGARDS.
PLZ. RATE THIS
My new computer is not
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
All of a sudden, when I turn my Olympus Stylus 750
You need to go into the menu and find the reset. click that and it may solve your problem. If it does not, remove the battery and leave it out for at least ten minutes then reinsert the battery and restart the camera. If neither of these resetting functions solves this problem you will have to take your camera to the shop or send it to olympus for repair. you can go to olympus.com to contact them If your camera is less than one year old it is under warranty. Good luck with it michelle.
Get a white screen when I turn the camera on!
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $144.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Dropped digital camera and it won't stay on
try taking ou sd card once maby u shocked it the lite card try it out oif not then most likey the main bord broke off a small connection sellon ebay broke or take it in for major repair i owuld try kodak v1233 models i own i droped mine once still works lol tuff cam full hd 12 mp
Why camera says one moment and does not seem to want to recognize computer
Most brands of cameras deliver a CD with the camera, containing software, needed to backup, transfer and work with the pictures you shot, to a computer.
Most of the time there is software is for both, Windows and MAC.
Before you connect the camera to any computer, you should install the software. The disk also has the drivers for the old operating systems.
If you lost the CD, or just don't know where it is right now, you can go to the site of your camera brand and try to download the software you need. For that look under support.
If your camera is old, and the brand does not exist anymore, try a freeware picture transfer / editing software pack. Like Gimp or Adobe Photoshop elements.
Just connecting a camera to a computer causes two things. The camera shuts down, and the computer won't recognise the camera. So nothing works.
If you can't get software form your brand, you always can install other generic software like Ulead, Pixir, BeFunkey, Gimp, Photoshop express. Or if that is not possible you could install an external memory card reader and download the pictures via de memory card reader.
Pictures will not download into pc
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Weird spots on camera screen
go out and purchase you some LCD tv screen cleaner and use that. It is safe to use on the camera screen, see if that fixes the problem.
Cannot remove battery
The type (model) of battery in use will determine the solution;
For most commercially available, consumer products, using a grounded (rubber/non-conductive handled screwdriver) is often enough to pry it loose. If extremely stuck, feeding a small length of twine or string between the battery and the device and pulling gently should be able to pry it loose.
For other rechargeable batteries (cell phones, MP3 players, etc.), you may have to find a way to insert a tool or string into the space for the battery.
Cheers.
Programming mode
I could copy the pages, from the manual, but why should I do that? you better read what is in the manual, direct. I could make an error while typing it from the manual.
