20 Most Recent Audiovox PPC 6700 Questions & Answers
manual
PPC 6700 Manual
Audiovox PPC 6700Uploaded on Oct 27, 2013
Password not working
In this case, I believe the only option is a hard reset, which restores the device to factory settings. To do this, press and hold down the left and right soft keys, and press the stylus tip into the tiny recessed reset button. This should guide you through the steps. Afterwards, you'll have to reinstall any programs that you had on the device, as well as syncing over any organizer info.
9/6/2012 6:42:18 PM • Audiovox PPC... • Answered on Sep 06, 2012
2answers
INCOMING CALLS
upgrade the phone to WM6 with A3.5 @ ppcgeeks.com --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
1/23/2012 9:09:28 AM • Audiovox PPC... • Answered on Jan 23, 2012
2answers
Unlock cellphone
if u wanna assist in this, just reach http://www.mobile-unlocker.com/
for more details.
12/19/2010 9:25:04 AM • Audiovox PPC... • Answered on Dec 19, 2010
Cant watch videos on wmp from mini sd card
i think you should have a trial of another kind of converter.
Video Download Studio can help you with this very well.
get a free trial from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you more or less!
6/28/2010 2:52:04 AM • Audiovox PPC... • Answered on Jun 28, 2010
It doesnt allow me to
I wonder if you already tried to go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab' and set the 'My network card connects to:' dropdown menu to 'The Internet'.
Just my 2 cents...
Hope you are able to sort your problems out.
Regards, Carlos
6/13/2010 3:55:27 AM • Audiovox PPC... • Answered on Jun 13, 2010
I have a audiovox 6700 ppc. The battery is not hol...
check charger , charging point of your phone and furthermore make sure phone screen save features is set to maximum
Regards
Marshal
Dhaka, Bangladesh
[email protected]
5/24/2010 3:36:10 PM • Audiovox PPC... • Answered on May 24, 2010
Flashing motorola Q9c to metro pcs
i master reset my motorola q9c its flashed to metro i lost all setting when i get ready to get on internet it says wrong login info
4/16/2010 2:40:11 PM • Audiovox PPC... • Answered on Apr 16, 2010
It wont turn on dont know if i is charging
If it will not turn on, even when plugged into the wall (can be done without the battery installed) it is a faulty connection/piece where the charger plugs into the phone. A good way to check would be to go to a cell phone store with those types of batteries and if one of their batteries works & your phone turns on, it is definitely the port the charger plugs into on your phone.
3/20/2010 12:01:26 AM • Audiovox PPC... • Answered on Mar 20, 2010
Audiovox 6700, turn on, stuck on initial screen.
your operating system probably crashed. you can goto the UT Starcom website and download the operations system. make sure you select the proper carrier. it is a very simple process that will show you step by step on how to re-flash your software. it will erase everything on the phone and put it back to factory settings. if it is a sprint ppc6700 feel free to call us or stop in our store and we will take a look at it for you. 317.337.0030 M-F 9-6 Sat 11-2
11/10/2009 9:09:57 PM • Audiovox PPC... • Answered on Nov 10, 2009
I want to do a
Just to clarify, you ARE holding down both soft keys (left and right menu keys with dashes on them) and pressing the reset button?
If so, and it appears to only perform a soft reset, there should be a "clear storage" option in PROGRAMS. It will prompt confirming your selection (just go through the prompts). This is an equivalent to a hard reset.
I hope this helps,
Bill
9/11/2009 9:13:59 PM • Audiovox PPC... • Answered on Sep 11, 2009
5answers
No sound is coming out my PPC 6700
I would try a system reset there might be something wrong with the PPC itself but you won't know until you try these other two if you are still experiencing difficulties synch your phone to the comp call in and have it reset to factory default settings and if it still isn't work take it in to the store and have a diagnostic test run on the phone itself sorry that is happening to you and I hope this helps :)
7/23/2009 10:59:21 AM • Audiovox PPC... • Answered on Jul 23, 2009
Wireless radio won't turn on - phone no longer works
You might try going to your comm manager which is in your programs list. Once you click on it it will take you to a screen that has 7 diff icons on it. If the one that looks like a phone has an X in the lower right hand corner click on it and it should solve your problem.
**Comm manager can also be axcessed by holding down the button on the left side under the slider bar if settings have not been changed**
5/10/2009 9:29:23 PM • Audiovox PPC... • Answered on May 10, 2009
3answers
I was in Digital Roaming
For clarification on your problem, may I know the FF.
  • is the mobile was prepaid/postpaid?
  • what model of mobile phone your are using?
  • what is your network provider?
  • the country you reside?
  • the country you are using right now the roaming features?
Thanks
5/7/2009 8:21:37 AM • Audiovox PPC... • Answered on May 07, 2009
PPC 6700-I'm So Lost! What Is My ISP, How Do I Get Online, Etc?
Hi. First of all, yes it is a whole new world for you, so I really don't know where to start. I think the best thing to do is giving you some advice, than maybe if you have another question mark in your mind about a particular subject, you can open a new topic in this community. To begin with, your device is a HTC Apache coded device, where you can see the detailed specs here: (http://www.pdadb.net/index.php?m=specs&id=332). After that, here is the link for the forum special for your device, where you can find updates&solutions: (http://forum.xda-developers.com/forumdisplay.php?f=252). Also, you can start learning the basics of using the Windows Mobile Operating System here: (http://www.microsoft.com/windowsmobile/en-us/help/default.mspx). And finally, when you move across a little bit, you can start to have a look at some of these great freeware applications for PDA's here: (http://www.1800pocketpc.com/), which, I think, is the greatest advantage of a windows mobile based PDA. Also, ISP stands for "Internet Service Provider", which in your case is same with your mobile carrier (because you'll connect to internet using your sim card). You can easily contact your mobile carrier (like Vodaphone) and learn their specific configuration for the data connection on your mobile. Hope this helps. By the way, your device also has a built-in wireless, so you can connect to any wifi network around and use the internet through it.
4/28/2009 8:00:29 PM • Audiovox PPC... • Answered on Apr 28, 2009
Volume
can you be more specific? are you using headphones?
4/24/2009 5:48:07 AM • Audiovox PPC... • Answered on Apr 24, 2009
Unlock sprint?
keypad of my Sprint 6700 is locked. even the touch screen
3/20/2009 11:27:59 AM • Audiovox PPC... • Answered on Mar 20, 2009
How do i get on
if you look at the bottom right corner there are 3 icons the center icon looks like a circle withe 2 curved lines is the comm manager use your thumb stick to navigate to it and push it in like a button there are 7 new items to select just under the phone is the wireless on off switch if it has a X on it then its off click on it..
now the wireless is activated and if you have a router you can connect to it and use your internet connection that way also there are many places that offer free wifi..........
to see what connections are on push the windows sighn go to settings on the bottom move it to connections then go to network cards and enter you will see a list of available wifi connections if your wifi setting is on....
3/16/2009 2:44:46 AM • Audiovox PPC... • Answered on Mar 16, 2009
Audiovox PPC 6700 Logo
75 questions posted
Top Audiovox Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Computers & Internet
Most Popular Question
unlock cellphone
  • Computers & Internet
