20 Most Recent
AOC 19LVWK LCD Monitor Questions & Answers
My AOC monitor has a
the AOC , connected to what.? a PC ,what PC
some PC has video control app that is bad.
called DCC2 or eDid controls to the monitor. GONE MAD?
if PC is windows, ? is it, put it in to safe mode
see if stops this.
and or, create a 2nd user, then log off and back on as 2nd user.
still fails>?
ok last, is in task manager is startup box.
in that box disable all start ups there.
or
ungrade the video card driver at AMD or Nvidia as it may be.
Vertical colour lines ( three lines Bule, Green
NOT ONE PHOTO OF FAILING SCREEN SHOW. POSTED
MAKE THIS IMPOSSIBLE FOR MILLIONS TO GUESS.
'WHY?
IT IS SAID 1 PHOTO CAN BE WORK A MILLION WORDS
FOR LCD PROBLEMS YES.
Your cell phone has a CAM use it.?
yes AOC is trash. was or is
they do not have manual on older monitors
as LG and viewsonic have.
they are lame.
3inches between them
but no one word on line itself thickness, 1 pixel
wow
Hi im having a display
You need to install a better device-driver for the video-adapter on your computer.
When you do, that device-driver will automatically recognize your "Plug-And-Play" monitor.
Open "Control Panel".
Open "System".
Click "Hardware".
Click "Device Manager".
Expand the "video-adapter" part of the tree.
Double-click the video-adapter.
Click "Reinstall Driver".
I have an AOC 19MVWk
It does the same when attached to another PC? It may be indicating that it is in safety shutdown/restart mode due to
shorted or failed circuits in the power supply due to bad caps or in the
backlights inverter circuits, you need to open it up and inspect the inside and circuits.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Hi
I have an AOC M19W monitor attached to my
Top three suspects
1. Change your display cable for a new one
2. Without being able to see the screen myself, try to monitor on a different pc, if your using it as a tv, then try different channels
3. Press and hold the power button for 15 seconds then release to reset the system
Monitor says no signal
Check the settings on monitor for "input" most of these have multiple input settings and make sure your pc output is set to "mirror"
