20 Most Recent
Toshiba Satellite A135-S4427 Notebook Questions & Answers
How do i reset my
This should work on every recent Toshiba laptop ().
- Start with you laptop turned off.
- While holding down the 0 (zero) key tap the power button.
- When you hear a beep, release the 0 key.
- select Yes to continue with the system recovery.
- Select Recovery of Factory Default Software and Next.
- Select Recover to out-of-box state and Next.
WARNING: the procedure will delete all data on your hard drive!!
3/9/2014 2:22:45 AM •
Toshiba...
Answered
on Mar 09, 2014
I HAVE A TOSHIBA SATALITE A135-S4427 TURNED IT OFF
Try removing the battery and power supply, hold the power button for about 10 seconds then just plug the power supply back in (not the battery) and see if it turns on.Holding the power button with no power supply can discharge any stored power in capacitors.
10/25/2013 6:07:59 AM •
Toshiba...
Answered
on Oct 25, 2013
Screen goes black
Please disconnect power cord. Remove battery. Hold down power button for a minute and connect power cord. If not working, please go to device manager and update display adapter or scan the computer with antispyware program.o remove malware/adware/spyware:Please scan your computer using free version of Superantispyware.
http://www.superantispyware.com/Please run quick scan.
6/4/2013 11:23:21 AM •
Toshiba...
Answered
on Jun 04, 2013
Need to restore computer ****
Follow below instructions......
To use System Restore to restore Windows XP to a previous state, follow these steps:
- Log on to Windows as Administrator.
- Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
- On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
- On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
- On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
- Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
- Click OK.
If
you successfully restored your computer to a previous state, and the
computer is performing as it should be, you are finished.
thank you.......
11/23/2012 1:03:33 AM •
Toshiba...
Answered
on Nov 23, 2012
How to reset factory settings
This laptop will sometimes need the CDs for a factory reset. Try the steps below. If "Repair Your Computer" is missing from Step 3 OR if you cannot find any of the listed options in Step 5, then you need your Recovery DVD. If you don't have a Recovery DVD, then you can have one mailed to you from Toshiba ((800) 457-7777).
1. Restart the computer.
2. Repeatedly tap the F8 key until you see the Advanced Boot Option Screen.
3. Select Repair Your Computer and hit Enter.
4. Select your keyboard layout >> NEXT.
4.5. Will have to login to their account. Hit drop-down, choose account, type PW. NEXT
5. On the System Recovery Options Screen select "Restore Application" (May be Toshiba Recovery Wizard, or System Image Recovery).
6. Follow the on-screen instructions.
7. Recover to Factory.
8. When prompted, select on "Full Factory Recovery" or "Recover to out-of-the-box state."
9. Select Next >> Yes.
10. After a couple of minutes the recovery will be completed.
I hope this helps! If you have any further questions, do not hesitate to respond to this post and I'll be happy to assist. If you found this helpful, please leave a great rating so others may benefit from from this answer too!
9/20/2012 6:04:53 AM •
Toshiba...
Answered
on Sep 20, 2012
Laptop has black screen
either screen, back light, screen cable or else but see if it outputs to a second screen via vga or hdmi to check that the onboard video is working first and you may need to swith it between using fn key and one of the f keys.
5/25/2012 11:18:00 PM •
Toshiba...
Answered
on May 25, 2012
Satellite A135-s4427
Hi I got
Need
drivers?
Always
get your drivers and specific software from the manufacturer of your
Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the www.toshiba.com
web
site,
usually one is able to download if available, by model
number,
All
available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing.
This is the best way of ensuring up to
date drivers for your system and they are free of charge!
I hope this helps.
2/27/2011 4:18:09 PM •
Toshiba...
Answered
on Feb 27, 2011
Can a second hard drive
it comes with 2 hard drives fitted as standard - you can replace them but you cannot add a third.
12/14/2010 3:06:33 PM •
Toshiba...
Answered
on Dec 14, 2010
When I star up my
Seems a problem with RAM.
Remove your RAM from the slot and start the PC, long beep sounds are audible, then the RAM is OK, else time to buy a new RAM/ memory.
Else Try for the Hard Disk, Check the Hard disk in your's friend's PC, remove his Hard disk and insert yours, if the same problem arises, change the Hard Disk or if nothing happens, system boots,
it seems a problem with motherboard, Get it repaired by a expert or buy a new one.this will work.
Enjoy !!!
Thank you for using Fixya !!!
11/14/2010 4:22:32 AM •
Toshiba...
Answered
on Nov 14, 2010
I am having Toshiba Laptop
Base from the description of your problem this can be a loose connection on your keyboard, what you can do here if the laptop is already out of warranty dismantling the laptop to check the inside will be a good thing to do.
This site will give you some steps that you need in cheeking the inside of your laptop, but if your laptop is still under warranty I suggest you use that warranty to have it repair.
Just click
HERE.
9/12/2010 2:08:22 PM •
Toshiba...
Answered
on Sep 12, 2010
