20 Most Recent
HP LaserJet 1600 Printer Questions & Answers
HP Printer Error code 55.1
Each of us has ever had at least one worry about choosing technique. You know, I didn't know what brand should I use in order to have more advantages from it. However, once my friend told me about this article:
Dell vs HP - Which Brand is Better? So that I decided which is better and now my problem is gone. I think it will be also practical for you.
Print multiple copies
Please check printer setting if you are any other printing setting then this types of issue create. If you are not set then Go to Printer icon and right click and property option and set default setting option. your printer also set auto. then you check it is not solved then reinstalled old printer driver and again installed printer driver i hope solved your issues.
Thanks,
HP Printer Support
How to replace hp 1600 drum unit from the cadgtrage
The HP 1600 uses an all-in-one toner cartridge and drum unit.
When you replace the toner, you replace the drum. The unit is NOT repairable or servicable.. you don't want to open the toner cartridge, you will only make a huge mess.
Instal supplies hp 2700n
check to see if the toners are full if not replace them and also have a look on the fuser and ITB unit.
Prints blue
Bad drum or bad laser. Replace the cyan print cartridge (not the toner), and see if that helps. If you still have the background, take it in for service.
