20 Most Recent HP LaserJet 4350dtn Printer Questions & Answers
Turn the printer off. Remove any jobs i the printercue. restart, and the printer should be OK.
HP LaserJet... | Answered on Sep 30, 2019
That means your driver is out of date. This software driverupdate us usually keep my drivers up to date (perfectly)
take a look
HP LaserJet... | Answered on Jan 29, 2019
Usually caused by a failed fuser, does the print smudge if you rub it?
HP LaserJet... | Answered on Dec 03, 2016
usely it's the fuser sleeve the problem. replace the fuser but before be shure the cartridge is ok. print something and open the cartridge door when printing to see under the cartridge the print quality if ok replace the fuser unit
HP LaserJet... | Answered on Dec 02, 2016
Typically the only reason that a printer beeps when printing is because you have the printer plugged into a UPS. None of the circuit boards on the 4350 have any sort of audio capability. Plug the printer right into the wall outlet.
HP LaserJet... | Answered on Sep 25, 2016
Yikes....Been there done that. If all fails, you will have to remove the entire front tray 1 assembly to get to the small pieces of paper. It is not real difficult but requires some time and attention to detail.
HP LaserJet... | Answered on Jan 31, 2015
The tray 2 lifter-motor is not functioning
Unfortunatly this usually requiers parts
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness is full seated in its connector on the dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver assembly
-If the unit is still clicking/banging with a new lifter replace the tray -If the unit is still clicking/banging with a new lifter and tray see step 5 5 Replace the dc controller PCA.
HP LaserJet... | Answered on Dec 03, 2014
This is not a message you would ever see on an HP printer. You will only get a "cartridge empty" error. In most cases you will need to replace the drum unit on the printer.
HP LaserJet... | Answered on Sep 06, 2014
Usual solution is to update the firmware of the printer. The quickest solution is to use a different printer driver. So if using PCL, try Post Script (or the other way around).
HP LaserJet... | Answered on Oct 15, 2013
Most likely the fuser has lost part of the teflon from the heat roller. Having said that, the first step in any print quality issues is to change the toner cartridge. good luck!
HP LaserJet... | Answered on Apr 26, 2013
Indicates that fuser is not cycling properly. Usually caused by a failed fuser. If your page count is anywhere near 200,000 pages, your best bet is to purchase a maintenance kit which will come with a new fuser, as well as the feed/separation rollers.
HP LaserJet... | Answered on May 28, 2011
49.XXXX PRINTER ERROR
To continue turn off then on
No error message will be in event log.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications. On rare
occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application. If the job prints, go back to
the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer. See Calibrate now.
HP LaserJet... | Answered on Feb 25, 2011
If you go to PRINTERS in the Control Panel.
Right click on your printer.
Drill down to PRINTING PREFERENCES
Go to FINISHING.
Make sure that "print on both sides" is checked.
Close that window. Now drill down to Properties at the bottom.
Go to "device settings". Drill down to "installable options".
Make sure that "Duplex Unit" is INSTALLED.
Print out the CONFIG pages. On the first page right side, look for duplexer. I believe that it is down where the paper trays are listed. Make sure that it is there.
HP LaserJet... | Answered on Feb 11, 2011
You have the same problem as WHAT???
Someone will attempt to answer your question if you ask one!
HP LaserJet... | Answered on Feb 08, 2011
Does it occur on any print job or one in particular. If it happens with one job, that job has a problem. It isn't the printer.
If it is all printing go the www.hp.com. then go to "support and drivers". Then select your printer, select your operating system, select firmware. Upgrade your firmware. Make sure that you read the instructions and DO NOT touch the printer while it is upgrading.
If the firmware upgrade completes and the errors continue, you will need to replace the formatter.
HP LaserJet... | Answered on Dec 24, 2010
HP LaserJet 4350dtn Printer Logo
62 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
service error 49 4c02
  • Office Equipment & Supplies
